T3i external HD monitor at DVinfo.net
Canon EOS Crop Sensor for HD
Old March 31st, 2012, 07:02 AM   #1
New to DSLR and a little confused on the search I did, so hoping someone knows . . . Can I monitor an HD signal out of the HDMI output of the T3i?
I do not have Magic Latern installed (reading mixed reviews about it on T3i). Thanks!
Myrtle Beach SkyTour http://www.myrtlebeachskytour.com
Ralph McCloud is offline   Reply With Quote
Old April 1st, 2012, 08:19 AM   #2
Re: T3i external HD monitor
Nobody with t3i and monitor?
Old April 1st, 2012, 10:34 AM   #3
Hi Ralph, answer is no you cant, well not in HD anyway.
The HDMI output is only SD during record. Playback via the HDMI is in HD.
Magic lantern is great, worth a try and works fine on my EOS600D
john
john estcourt
www.amourweddingvideos.co.uk
John Estcourt is offline   Reply With Quote
Old April 2nd, 2012, 07:27 AM   #4
Thanks John. Saves me from buying another monitor!
Old April 4th, 2012, 03:42 PM   #5
From what I understand this monitor solves the SD resolution problem with the 5D/T3i - and provides HD on Record and Output for Canon and Nikon Cameras - 5.6in 1280x800 On-Camera Field Monitor - the DP6 by SmallHD - You can download the User's Manual to read about it.
Cheers!
Reuben Miller is offline   Reply With Quote
Old April 7th, 2012, 07:47 AM   #6
See this thread as well:
http://www.dvinfo.net/forum/view-vid...ml#post1724355
stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old April 9th, 2012, 06:57 PM   #7
I picked up a Jag35 monitor, which I believe is a rebranded lilliput or similar. Jag35 Monitor | Jag35.com
Two questions:
For a T3i, what cables do I need? Will it be able to display in HD, and will it have the "shutter/squeeze" issue?
And I believe I need a battery adapter. What should I use that is cost-efficient?
Charles House is offline   Reply With Quote
Old April 11th, 2012, 08:57 AM   #8
You'll need a mini-HDMI to HDMI cable. The T3i will let you focus in HD, but as soon as you hit record you will see a stretched SD image on the screen.
The DP6 mentioned above is a solution for those who wish to keep the monitor feed at Full HD when framing or shooting.
Old April 20th, 2012, 08:51 AM   #9
Make sure you get a HD monitor if you do get one, I've used a "HD" monitor that the resolution was only 800 x 480 so it doesn't really help to use a monitor other then framing shots. When I compare it to a SONY HD Monitor (which is like £2000 mind) you can tell the difference instantly.
Matt Thomas is offline   Reply
