FD to EF mount adapter - it's that simple? at DVinfo.net
Canon EOS Crop Sensor for HD
Old July 30th, 2011, 04:56 AM   #1
There are some very cheap FD mount lenses on Ebay. Is it just a case of buying a cheapie FD to EF mount to attach one of these, let's say a 50mm 1.4 prime, onto my 60D? I know that focus and aperture will all be done manually by the lens rings but it is that it?, nothing else to be aware of? It just sounds too easy and too cheap..!
Dan Burnap is offline   Reply With Quote
Old July 30th, 2011, 06:36 AM   #2
Re: FD to EF mount adapter - it's that simple?
Sadly no. The distance from the back of the lens to the sensor is wrong so an adaptor needs to have a lens in it to focus on the sensor correctly. The problem is that with the cheap $30 FD to EOS adaptors usually available that the lens in them is pretty poor quality. When Canon introduced the EOS mount & killed FD they produced a high quality FD to EOS adaptor but that only works with the top of the line expensive FD mount telephoto lenses (I think that 200mm was the minimum). It is also possible to buy a glassless adaptor that does allow focus to infinity but only for the extreme telephoto 600mm & 800mm FD lenses http://cgi.ebay.ca/ws/eBayISAPI.dll?...#ht_611wt_1141
The sort of lens that you get in a $30 adaptor isn't going to give a very good image.
However I have recently heard of a new higher quality adaptor available at around $100 & have just ordered one myself as I have a nice collection of FD 'L' lenses. CANON FD - EF EOS ADAPTER AF CONFIRM UK DESIGN | eBay
The final option is that it is possible to get FD lenses converted to EF mount but this does require machining by a skilled craftsman & consequently is not cheap.
Old July 30th, 2011, 07:32 AM   #3
thanks Nigel, i knew it wouldnt be simple!
Old July 30th, 2011, 09:36 AM   #4
Nigel,
Once you receive the adapter, please let us know how it performed. I also have quite a few FD lenses that I'd like to use, but haven't found a decent adapter.
Thank you,
Phil
Phil Murray is offline   Reply With Quote
Old July 30th, 2011, 04:39 PM   #5
I'm also looking for a Canon FD converter that doesn't make things look like there's a heavy fog.
Galen Rath is offline   Reply With Quote
Old July 30th, 2011, 05:18 PM   #6
With the glass adaptors you also get a further 1.3x crop factor with all your lenses - and thats on top of the 1.6x crop of the aps-c sensor. So your 50mm lens becomes a 65mm lens with a FOV equivelant to a 104mm lens when used on the 550D.
John Wiley is offline   Reply With Quote
Old August 2nd, 2011, 12:57 PM   #7
I am afraid as long as adapter uses cheap glass it'll be the same poor quality adapter with different name, I tried a few of them, they all make FD lenses soft
I love this place!
Old August 2nd, 2011, 07:10 PM   #8
I agree, Buba. I'm curious, though, to see how Nigels' new adapter works. Guess I'm being too hopeful Seems like SOMETHING has to work eventually...
Old August 3rd, 2011, 02:38 AM   #9
I'll let you know when I receive my adaptor but I am optimistic as the adaptor is not a cheap Chinese plastic one but made by a proper craftsman here in the UK who repairs & services lenses. FD to EF Adapters
Old August 3rd, 2011, 06:30 AM   #10
please do, I really hope you're right about that one
I love this place!
Old August 8th, 2011, 04:45 AM   #11
I have one of these adapters, and I'm very pleased with it; the guy who makes them is very responsive to queries too.
Nick Gordon is offline   Reply With Quote
Old August 8th, 2011, 07:21 AM   #12
That's good to hear. I may ask him about getting my FD lenses de-clicked & permanently converted to EF mount as it seems unlikely that I shall ever use them on a camera that they were designed for. I am in France ATM but will be back in the UK in a couple of days so hopefully my adaptor will be waiting for me.
Old August 10th, 2011, 07:31 AM   #13
yesterday i tried 135mm f:2 with another FD to EF adpter, without glass , razor sharp image where you able to focus, but it's a very limited focal length range where you can get a focus
I love this place!
Old August 26th, 2011, 09:29 PM   #14
Just a note - Canon FL lenses are apparently easier to convert. I sent a 55mm f1.2 for conversion to Jim Buchanan. Came back looking beautiful. This lens much less expensive than the FD version and is phenomenally sharp at 2.0. It has a click at 1.4 that is useful and 1.2 is there when you need it. The conversion was $125. Before and after conversion pix attached.
FD to EF mount adapter - it's that simple?-img_6729.jpeg   FD to EF mount adapter - it's that simple?-img_6890.jpeg
WeddingFilms.com>>
Joel Peregrine is offline   Reply With Quote
Old August 27th, 2011, 03:00 AM   #15
Sad to report but the FD to EOS adaptor is OK but not great. It is much better than the cheap versions but comparing between FD lens plus adaptor versus a native EF lens the sharpness is way down. It may be that the old FD (50mm F/1.2L, 24mm F/1.4L etc) lenses that I have are not great examples or that the modern EF 'L' lenses I have (70-200mm F/2.8 etc) are so much better in comparison. The adaptor i usable but no substitute for a native lens.
Nigel Barker is offline   Reply
