Canon Rebel T3i 18-55mm stock lens at DVinfo.net
Canon EOS Crop Sensor for HD
Old July 9th, 2011, 01:37 PM   #1
I'd like to find out if anyone else has an issue with the 18-55mm lens that ships with the Canon Rebl 3ti.
The focusing barrel on mine is kind of a loose fit - it wobbles about 1mm each way and that's visible in the recorded picture. I'm not talking about the connection from the camera to the lens - just the focusing barrel.
In addition, I'm not sure if the Stabilization actually works at all on this lens. I can't see any evidence of stabilizing. It seems to record every tiny little movement of my hands. Either it doesn't work - perhaps my lens is faulty - or perhaps I am expecting too much. I have a Canon XLH1 which has excellent stabilization.
Another thing: is this just a cheap nasty lens, or is it my eyes? I don't think much of it. I see softness even when I know then picture is as sharp as I can get it.
Opinions appreciated.
Harry.
Harry Bromley-Davenport is offline   Reply With Quote
Old July 11th, 2011, 10:47 PM   #2
Re: Canon Rebel T3i 18-55mm stock lens
For my son's T2i we immediately replaced the "stock" lens with the Canon EF-S 15-85 IS lens. Though not constant aperature, it is a much better lens. See reviews at still photography sites like fredmiranda dot com and the-digital-picture dot com. To use my 77mm filters I bought the Heliopan 72 to 77 step-up ring. A bit expensive but a well-built step-up ring (brass, I believe) that does not jam.
Richard D. George is offline   Reply With Quote
Old July 12th, 2011, 08:30 PM   #3
Thank you very much for the response. Next week I'll go down to Samy's camera to do a test.
I appreciate the response.
Best wishes,
Harry.
Old July 13th, 2011, 02:38 PM   #4
The full name is EF-S 15-85 mm f/3.5 - 5.6 IS USM. I think I paid close to $800 for it, plus the lens hood (sold separately). If you plan on investing in filters, 77mm is a smart choice. Therefore, you would also want a 72mm to 77 mm step-up ring.
If you check reviews, you will find that this is actually a really good lens (though not constant aperture) - much, much better than the "stock" lens.
A great lens for stills. For video you should not zoom while shooting, and it will not be ideal for low light.
Old July 28th, 2011, 01:43 AM   #5
Harry.
It is a $100 lens and the build quality is somewhat poor. The optics and stabilization, however, are quite good and have received excellent reviews. You either have a bad copy or there is some type of user error.
Have you turned on the IS switch?
Sam Kanter is offline   Reply With Quote
Old July 28th, 2011, 02:58 AM   #6
I got this lens when I bought the kit because the T3i body only was not in stock at B&h. My copy seems soft to me and I seldom use it.
Willard
http://pawildlifephotographer.blogspot.com/
Willard Hill is offline   Reply With Quote
Old July 29th, 2011, 02:45 AM   #7
I might add that this is more noticeable with stills, and the lens is more acceptable for video use, but I end up using other lenses as they work better.
Willard
