How to convert Canon T3i .mov files for editing in FCP etc...? at DVinfo.net
Canon EOS Crop Sensor for HD
Old June 4th, 2011, 06:51 PM   #1
I know it has probably been a topic of discussion at some point in this or other forums regarding DSLR video acquisition, but I would be most grateful to the community for hints or pointers to threads that talk about how to convert / import T2i / T3i .mov files into editing software of any kind and more specifically into FCP? I know there is a solution from Canon for the 60D but don't see one (yet - there may never be one) for the Rebel series (T2i, T3i). Thank you - this may save me a lot leg work in sussing this out.
Duane Harper Grant is offline   Reply With Quote
Old June 4th, 2011, 08:42 PM   #2
Re: How to convert Canon T3i .mov files for editing in FCP etc...?
Hi Duane.
I've only been researching the T3i since yesterday (when I decided I might pick one up next month for some small personal side projects).
I found this FCP plug-in for Canon which (apparently) lets you directly use the Log and Transfer function in FCP.
According to Canon:
"This plug-in application is for Final Cut Pro, which was released for users of EOS Digital and Final Cut Pro. This plug-in allows you to use the Log and Transfer function to edit movies captured with the EOS cameras."
So it looks like it "might" be suitable for T3i (and any other EOS camera).
Follow this link:
Canon U.S.A. : Professional Imaging Products : EOS 5D Mark II
and then, from the drop-down menu in the "Drivers & Software" section, select "Mac OS X" and then a bar called "Software" will then appear underneath. Click "Software" and a list will appear. About the third one down you will find a plug-in called "EOS MOVIE Plugin-E1 for Final Cut Pro Ver1.2" (File Name: ce1120x.dmg.zip)
Only experienced T2i/T3i users can actually tell you if this really works, but I love using the Log and Transfer plug-in from Sony when working with my EX1R footage, so I imagine that the functionality might be similar. But, as I said, only experienced users can say how truly workable this solution is.
David Knaggs is offline   Reply With Quote
Old June 5th, 2011, 03:51 AM   #3
Thanks very much David. I will give this a shot. I knew about this but because Canon did not list the Rebel Cameras at all in the supported devices I reckoned that that omission was intentional and it would not work but again, this is worth a try. I will let you know.
I wonder how Premiere handles the .mov files and what those editors are using if they need any conversion. I did a little experiment with I movie (9) to directly import .mov files. The results were not usable at all.
Old June 5th, 2011, 05:39 AM   #4
Duane,
In Premiere the files import just fine.
Dave Chilson
www.loc.org
David Chilson is offline   Reply With Quote
Old June 5th, 2011, 11:00 AM   #5
Good to know David. Seems Adobe has a few legs up and are on the ball over Apple. To bad for me the price of CS5 is out of my league just now 'cause I would seriously consider bolting from FCP.
Old June 6th, 2011, 02:54 PM   #6
If you're willing to try a PC, I just installed Avid's Pinnacle Studio 15 on my year and a half old Core i7 2.66Ghz processor based Dell and the .MOV files from my 7D, T2i, and 60D edit "natively" with no conversion, transcoding, or other "tap dance" required.
It will take a fast multi core (quad core or six core) processor based computer but that's where everything seems to be heading anyway.
Old June 6th, 2011, 10:53 PM   #7
Hi Bruce,
Thank you - that is very interesting. I do have an intel mac running a 2.3GHz i7 processor which I just got, but this machine will run windows apps with parallels. It may be something to consider down the line. I am still sussing this out. I have found some interesting things but too random to report on now. Meanwhile, I'm dusting off my tap shoes.
Old June 7th, 2011, 11:11 PM   #8
use the free MPEG StreamClip to batch convert your .Mov H.264 to Prores LT or ProRes what ever you prefer. It much faster then the log and transfer
Thanh Nguyen is offline   Reply With Quote
Old July 25th, 2011, 07:30 PM   #9
Thanks Thanh,
I have been meaning to update this thread. I did get this free program and tried it and it worked really well. Good recommendation. I used the Apple ProRes 422 option from quick time options box then imported the footage into FCP. Log and transfer not needed. Video worked great in the time line. Can do batch conversions too.
Old July 30th, 2011, 07:06 AM   #10
The advantage of using Log & Transfer versus blindly converting all your video clips to ProRes is twofold as you get to quickly skim through the clips marking in & out points & only need to convert to ProRes what you actually want & need & not every last second that you shot.
Old August 2nd, 2011, 07:58 AM   #11
Nigel, you can trim in MPEG Streamclip, too. Not in batch, but it can easily be done.
Bryan Cantwell is offline   Reply With Quote
Old August 2nd, 2011, 12:19 PM   #12
I know that but quickly being able to skim through all the clips mark in & out points & send them off to the queue to be converted to ProRes is much nice & more easily done with Log & Transfer.
Old August 6th, 2011, 09:18 AM   #13
The other big advantage of Log & Transfer is that it should convert your time-of-day timestamp into timecode, which is very useful. If you don't care about TC, then Compressor is a much better solution than mpeg streamclip or FCP. I've found that ProRes LT is just as good as ProRes and much smaller- but I haven't done any heavy compositing with this footage.
David St. Juskow is offline   Reply
