ND Filters suggestions?
Hey guys,
So I bought this cheap nd filters kit off of ebay which conists of a ND2, ND4, ND8 filters for the price of 15$ for my 60D. For that price I wasn't expecting much but I gave it a try. As expected they were not of the best quality. It gives too much of a red tint to the footage. The ND2 alone is not that bad but when you put all three together is just ridiculous, it's as if I put a red filter in front of the lens. So do you guys have any suggestions as to which kind (brand etc) of NDs I should use? Obviously I'll need filters that won't change (or not much) the color or overall quality of the image. I'm open to faders too even though they are a little more expensive. Thanks! |
Re: ND Filters suggestions?
Ive heard nothing but good things about B&W and thats who I plan on getting my NDs from as well.
Yeah I've seen a 0.6, 0.9, 1.2 nd kit from Tiffen on B&H for 41.95$ I don't know if they would be any good for video in terme of quality/color etc? I guess they would be better than the ones I bought anyway.
I'm trying the variable ND fader version, two filters that rotate to go from min effect to max effect. Seem okay so far. They are all prices/quality from $60 to $250 or more. Get the size that will fit the largest lens you will ever have, and then get a complete set of step up adapters to fit the filters onto your smaller lens.
#5 |
I just have an ND 0.9 and would like to add an ND 1.8 for timelapse. I don't see much of a need for one or two stop increments. The ISOs (100, 160, 320, 640, 1250) of the camera are good enough that I just need to get things in the right range and adjust the camera from there.
Jon Fairhurst |
#6 |
Thanks guys, any other suggestion is welcome.
Jon, 0.9 would be the equivalent to ND8 I guess? If so, it's really not enough when shooting on a sunny day with the aperture wide open (f1.8). I put all three filters (nd2, nd4, nd8) one in front of each other and it's barely enough add to that the red tint. |
#7 |
Yeah, that's why I recommend a six stop filter as well. I just haven't purchased one yet.
Though frankly, I don't generally shoot wide open outside. My main use is to get blur on timelapses. And on a timelapse, I often shoot at f/16 or so. In any case, a three stop and six stop ND have real value. I don't sweat one stop increments. Also, you can use a polarizer to reduce light a bit further when you run out of ND. :)
Jon Fairhurst |
#8 |
Thanks Jon.
So the red tint that my NDs give is mostly due to the low quality of the filters right? Or is it a common problem with ND filters? |
#9 | |
#10 |
I got the LCW vari-ND and I hate it. I went with the 82mm version with step down rings for all my lenses so its compatible with everything. No matter the lens, either prime (28, 35, 50, 85) or zoom (24-105, 70-200) I get that stupid X after only 3-4 stops max. So yes technically it will cut 8+ stops of light, but only 3-4 are usable. What a rip. The Genus version appears to be from the same manufacturer. I've debated trying the pricier Singh-Ray or just getting 2 or 3 Tiffen IR's that supposedly won't cut resolution or funk with color. I shoot out in bright light quite often so some sort of ND is a vital part of my kit. For now I'm making do with the LCW. I'm going to be in NYC in a few weeks - so I'll be heading to B&H to find a better option.
#11 |
Could you elaborate a bit further on this matter please? I'm thinking of buying this to...
#12 |
I purchased a 77mm Genus variable ND for use with a Canon T3i. It worked fine with the EF 10-22mm f3.5-4.5 lens and the EF 24-70mm f2.8 lens. But when I tried it with an EF300mm f4 lens, the image quality was totally unusable with massive loss of resolution.
I have seen it posted elsewhere that varying light loss by stacking two polarized filters with their polarizations nearly 90 degrees apart, causes significant optical issues. My experience was that the degradation was acceptable at ordinary focal lengths, but completely unacceptable in the telephoto range. My new B+W 77mm NDs tested with perfect performance (zero degradation) even with the EF 300mm f4 lens. |
#13 |
probs best this is what i am planning to do.
been said early. Get a 77mm or 72mm fader and get step up rings. nd2-nd4 and different rings. seems the best answer :) |
#14 |
If not 82mm. Many wides have 82mm threads.
Jon Fairhurst |
#15 |
good point.
do you buy faders bigger size than add step up rings etc? i am looking at some rubber lens hood look great. |
