New Canon FCP Plug-in for Log & Transfer at DVinfo.net
Canon EOS Crop Sensor for HD
Old April 26th, 2011, 08:08 AM   #1
Has anyone found the new Plug-in for FCP that was supposed to be released on 4-25-11?
John Richard is offline   Reply With Quote
Old April 26th, 2011, 12:20 PM   #2
Re: New Canon FCP Plug-in for Log & Transfer
Do you mean this one? - v1.2 Released on the 15/04/11
Canon U.S.A. : Support & Drivers : EOS 7D
(Select OSX from the dropdown to see it)
Dave Farrants is offline   Reply With Quote
Old April 26th, 2011, 02:34 PM   #3
No, and I have been looking. I was starting to wonder if it was bad info - though there was a fair amount of chatter about it from a number of sources.
"Canon is releasing a new update for their EOS to ProRes 422 conversion plug-in for Final Cut Pro. This new version (1.2) converts footage twice as fast as FCP’s converter and allows you to convert footage from any folder. The update will be available for free on April 25th."
David Decker is offline   Reply With Quote
Old April 27th, 2011, 12:00 AM   #4
I think you'll find the v1.2 that I mentioned is the latest update available, more info here:
Canon post latest 1.2 update of EOS Movie Plug-in-E1 for Final Cut Pro
Old April 29th, 2011, 07:34 AM   #5
Is anyone else having problems with their Log & Transfer crashing FCP since installing the EOS Plugin?
Mine crashes every time - I point the Log and Transfer to either the card with the files or a drive location with the files. The little spinning wheel starts to load the location in the Log & Transfer window - then the spinning segmented wheel freezes and then FCP shuts down with "Do you want to report this error" message.
Old August 30th, 2011, 11:55 AM   #6
Is there any way any of you can share the .dmg? I'm not finding this plug-in anywhere. I pull up my operating system on the canon 7d webpage, go to software and I'm not finding any plug-ins. Thank You.
Dawn Minenna is offline   Reply With Quote
Old August 30th, 2011, 11:58 AM   #7
Correction. Look for it under OSX - not 10.6 etc, it's not listed. Just FYI.
