Headphones on a t2i? at DVinfo.net
Canon EOS Crop Sensor for HD
Old April 10th, 2011, 12:08 AM   #1
Is it possible to have headphones w/o getting something like a Beachtek adapter kit?
John Vincent is offline   Reply With Quote
Old April 10th, 2011, 05:18 AM   #2
Re: Headphones on a t2i?
John,
It looks like if you load the Magic Lantern firmware you can use headphones with a special (or heavily adapted) mini-usb to headphone cable:
Magic Lantern Headphone Monitoring - Canon T2i and 5D MkII - DSLR Accessories and Features (5D Mark II, 7D, T2i, 60D, etc.) on Vimeo
Roger Shealy is offline   Reply With Quote
Old April 10th, 2011, 07:14 AM   #3
Yes it can. I use it successfully. Just enable the audio output in the magic lantern menu, use the mini USB to rca cable that comes with the camera combined with a stereo RCA to female mini adapter.
Brian Tori is offline   Reply With Quote
Old April 10th, 2011, 02:30 PM   #4
Brian - thanks a ton man - just ran up to the Shack and got a couple of adapters. Presto! I can actually hear sound now!
One little tip, plug the mini USB after the camera is on, otherwise it appears to bypass the view screen and output the video down the yellow RCA wire.
THANK YOU!
(and God bless everyone at ML)
Old April 11th, 2011, 07:52 AM   #5
No problem. I'm glad you got it to work. And yes, I forgot to mention you must connect USB after powering camera on.
Old March 24th, 2012, 04:07 PM   #6
THANK YOU!
Thread bump! What adapters did you buy at Radio Shack? I can't seem to find any that work.
T.L. Westgate is offline   Reply With Quote
Old May 7th, 2012, 10:35 AM   #7
You will need a RCA female to mini-jack female. That is, if you have mini jack-headphones.
I found one just like this one:
Except you will need the mini-jack to be female.
Also remember, that in the setup above, it will be MONO over STEREO, so you will probably only hear through one earpiece.
If you record in MONO you will need and RCA to mini-jack female, then an mono mini-jack to stereo mini-jack. Then headphones.
Marius Tatarasanu is offline   Reply With Quote
Old May 7th, 2012, 12:06 PM   #8
Another way round this is to buy a little AV monitor with headphone jack.
Donald McPherson is offline   Reply With Quote
Old May 8th, 2012, 04:27 PM   #9
Does this work for the t3i too?
Ben Davies is offline   Reply With Quote
Old May 8th, 2012, 07:24 PM   #10
No it doesn't work on the T3i, yet at least. I wish it did as I'd rather shoot with my T3i than the T2i.
Brett Sherman is offline   Reply With Quote
Old May 9th, 2012, 05:38 AM   #11
It's the only solution if you don't use Magic Lantern or you have the T3i.
