60D + Cineform ( ReMaster settings ) at DVinfo.net
Canon EOS Crop Sensor for HD
Old March 8th, 2011, 08:08 PM   #1
Hi
I was wondering if anyone else around here has a 60D and is using ReMaster to transcode their h264 into Cineform codec?
If so - what settings were you using on your input file?
Im at this so far:
Limit YUV ( 5D ) - it says 5D but Im wondering if this is also applicable to 7D and 60D family??
420 to 422 filter ( check ON )
601 Source ( check ON ) -- I know that I read previously that Canons are sadly producing 601 color space but has this changed with newer models or firmware?
Anyone else using Cineform stuff and a 60D around here?
cheers
Tj
T.J. Marbois is offline   Reply With Quote
Old March 24th, 2011, 03:45 PM   #2
Re: 60D + Cineform ( ReMaster settings )
I'm currently using Cineform. The settings you described are the correct ones to transcode to Cineform to the best of my knowledge.
I have found that this is the best way to use footage from Canon, 5D, 7D, 60D etc. It handles the colorspace very well and also minimized the aliasing to a minimum, giving you a beautiful picture to work with. We are now testing this method for a feature film taking the footage from Cineform, grade and to DCP for cinema.
Bragi Hinriksson, Little Big Films, Iceland.
Bragi Hinriksson is offline   Reply With Quote
Old March 25th, 2011, 10:55 AM   #3
Lately, I`ve had serious and unsolved problems with neoscene (Cineform) after transcoding stuff from Canon HV20 (HDV) using Vegas 9.e, despite the good quality of the codec .
Afterwards, I used a solution to transcode stuff from Canon T2i to my Vegas 9.e that have been working very well: I trancoded to Sony MXF 1920X1080 and couldn`t notice any diference from the original.
If you use Vegas 10, you can edit from the Canon original.
Ron German is offline   Reply
