Access to battery with CineFocus DSLR baseplate? at DVinfo.net
Canon EOS Crop Sensor for HD
Old January 23rd, 2011, 05:01 PM   #1
Anyone know if the CineFocus DSLR baseplate allows you to remove battery on 7D (or 5D) without having to take it off the plate?
Dennis Hingsberg is offline   Reply With Quote
Old January 24th, 2011, 05:32 PM   #2
I don't have that piece specifically, but it seems as though the battery compartment on the 7d would be just enough out of the way to not cause issue. Good luck!
Nick Popa is offline   Reply With Quote
Old January 24th, 2011, 06:44 PM   #3
I watched a video where I saw for sure the RedRock DSLR plate allowed you to remove the battery no problem. I'm sure they are all similar in that sense, I will message RedRock directly or check their site. That info is probably listsed there.....
thanks for the reply.
Old January 24th, 2011, 11:10 PM   #4
The RedRock DSLR baseplate definitely allows battery removal. Just make sure to attach it with the "screw" opposite the battery side.
Redrock Micro - DSLR/HDSLR Base Plate
Jon Fairhurst
Old January 26th, 2011, 11:39 PM   #5
You never know so it makes sense to double-check. Thanks for the replies!
