Recommend a tripod? - Page 2 at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 7th, 2010, 11:42 PM   #16
The Manfrotto 501 / 503 heads are not really up to the task for HD. Don't take my word for it - search the sticks forum on this site. The 504 might be different - the Chris Soucy comparison test (in progress) will be interesting. The best choices would be true fluid heads from sources such as Sachtler or Vinten.
Richard D. George is offline   Reply With Quote
Old December 11th, 2010, 09:05 PM   #17
all the manfrotto / bogen 500 series heads are crap. they are cheap, and the will not do what you want.
personally I have the predecessor to the vinten vision blue, the vision 6 head. its a decent setup and you can pick one up for $1k or less used. only single stage legs, but for more basic shooting its ok. I finally got myself a set of baby legs to go with it. if you can get 2 stage legs, do it. you'll have no regrets.
as for the gitzo tube legs, they are such a PITA to work with... you can to turn each leg lock, its slow, clumsy, and if you don't get it 100% it will slide. then most folks have the gitzo without a spreader so you will be messing around to even up the set of the legs. if you are on a slippery surface, they can move. I'm sure some one will tell you how great they are, but having used them in real run & gun news / doc shooting, they suck to use more then most pro legs out there.
get something with a single motion leg lock, where you know its fast, its locked.
Steve Oakley DP • Audio Mixer • Editor • Colorist
http://stevenoakley.com
Steve Oakley is offline   Reply With Quote
Old January 10th, 2011, 08:59 AM   #18
I tried a Sachtler DV1 head on ENG 75/ 2D sticks recently, and it was perfect for the 7D with a medium sized zoom lens. The configuration is really light weight but stable, and the fluid head works perfectly for a lightweight camera.
I don't think they make the DV1 head anymore, but any of the small heads for DSLR or HDV cameras should be fine.
Every Manfrotto tripod I ever used was mediocre at best, some were horrible. Sachtler is another league, their products are more expensive, but they're worth the money.
I mean you can use a good tripod forever, so why not invest in a really good one?
Heiko Saele is offline   Reply With Quote
Old January 14th, 2011, 12:12 PM   #19
my guess
I have the single stage Miller DS-20. The head is amazing and the legs have 3 knobs you turn and the legs fly out and you tighten. I have the mid spreader which is what you want and not the floor spreader.
I would get carbon legs to make it lighter.
My two stage Miller is a bit more of a pain to open and close and for documentary you might not need the extra height.
Kelly Langerak is offline   Reply
