Looking for Mount 1/4" 20 to 1/4" 20 at DVinfo.net
Canon EOS Crop Sensor for HD
Old September 23rd, 2010, 05:45 PM   #1
Hey,
Does anyone sell a 1/4" 20 to 1/4" 20 mount that is not a long arm and has the studs at both ends? All I can find is small ball heads with either the 1/4" 20 end with a shoe on the other end or thread but not the stud. Links would be appreciated. thanks!
-Mike
Michael Ferrara is offline   Reply With Quote
Old September 23rd, 2010, 07:37 PM   #2
1/4 20 is a standard hardware thread.
What you want will be found in most hardware stores in the nuts & bolts section. If need be, just cut (using a threaded bolt cutter) or hacksaw the head off a 1/4 20 bolt and file it down to dress up the threads.
Howard Harrelson is offline   Reply With Quote
Old September 24th, 2010, 06:54 AM   #3
Thanks. I was hoping to find a ball mount with studs and the circular pads on both ends though. If not, i guess that is the only option.
Old September 24th, 2010, 08:55 AM   #4
We have lots of options....Manfrotto, Ultralight, etc....check out the site
Jim Martin
FilmTools.com
Jim Martin is offline   Reply
