Urgent -- aperture wheel stopped working at DVinfo.net
Canon EOS Crop Sensor for HD
Old September 8th, 2010, 04:33 PM   #1
The aperture wheel on one of our 7d's has stopped working. I can not change the aperture in manual mode, nor can I scroll through photos or the menu. I was scrolling through photos when the wheel stopped working. I've turned the camera on and off, I've removed batteries and the CF card.
Any thoughts?
Benjamin Richardson is offline   Reply With Quote
Old September 8th, 2010, 05:33 PM   #2
I'm sure you've checked the aperture dial lock switch to make sure it isn't locked. That one still gets me on the 5D2 when I turn it on/off, though the 7D design makes accidental trippings less common.
Old September 8th, 2010, 09:20 PM   #3
That was the first thing I checked - and I switched the lock back and forth, but it wheel still doesn't seem to work.
Old September 8th, 2010, 10:53 PM   #4
It's usually the LAST thing I check. :)
Let us know if you get it figured out.
Old September 11th, 2010, 06:18 PM   #5
turn off the camera, take off the battery and cf card with it all out turn the camera on and back off, then replace the battery and cf card see if that'll work
Michael DiFilippo is offline   Reply With Quote
Old September 12th, 2010, 04:50 PM   #6
I would lean towards the rear switch or wheel being broken at this point.
Kin Lau is offline   Reply With Quote
Old September 20th, 2010, 03:40 PM   #7
Contributor
If he's in one of the auto modes it might not work, or if using a manual lens.
Old September 20th, 2010, 04:53 PM   #8
It stopped working while he was scrolling thru the photos.
