Fader ND filters - Any recommendations? - Page 4 at DVinfo.net
Canon EOS Crop Sensor for HD
Old October 10th, 2012, 10:33 AM   #46
Re: Fader ND filters - Any recommendations?
I have the light craft workshop and really don't like how it degrade the image. Anybody use Tiffen here and can comment on them?
Victor Nguyen is offline   Reply With Quote
Old October 27th, 2012, 10:41 AM   #47
I've been using the Fader ND Mk II for a while and recently started using the newer Digi Pro-HD version.
Built quality is better and it's overall easier to handle. It still gets a bit soft when on telephoto lenses but more common focal lengths it should work great.
Here's a review we did of it recently (Click CC for English subtitles)
Iker Riera is offline   Reply With Quote
Old October 27th, 2012, 03:46 PM   #48
I bought a Fader ND way back because I baulked at the asking price for the Shing Ray. It is garbage at anything past its half way setting, causing uneven vigetting, and a pronounced, but also uneven colour cast. I never ever use it, but my concience won't let me pass on such a lemon to anyone else.
So I now use Formatt Hitech 100mm resin filters, but besides a set of three GNDs, I only have the eight stop ND with gaskit, and it works flawlessly. To look through it is like a welding mask, but its effect is completely even across the frame, and there is no noticable colour cast.
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply With Quote
Old November 2nd, 2012, 10:59 PM   #49
Below are two pictures, the first was taken through a Fotga “Slim wide band FADER ND design for digital camera” variable density filter and the other through a Hoya UV(0) filter that I use as a lens protector. The Fotga is about $20 au including postage.
To eliminate camera movement as far as possible the Nikon D300 was tripod mounted and used in mirror up mode. The lens used was a 300 mm f4 Nikkor and the camera was set in aperture priority mode (f 5.6). The camera set the exposure that varied over an 8 fold range.
I used the full range of Fotga settings and the results were all very similar, i.e. no better or no worse anywhere over the full range.
Apart from the results l Iike everything else about the Fotga. I would be interested in seeing the results from more upmarket filters.
http://www.dvinfo.net/forum/images/a...attach/jpg.gif
Fader ND filters - Any recommendations?-_dsc9054.jpg   Fader ND filters - Any recommendations?-_dsc9061.jpg
Old November 5th, 2012, 10:21 AM   #50
I purchased a bunch of these filters and tested them on a GH2. The overall winner for me was the Fader HD. It is their most expensive and is made for video use. It has a two stop difference over the Heliopan.
Old November 5th, 2012, 08:00 PM   #51
Though I my tests were with a DIY vari-nd, it shows the same results as your's with a long lens, mine was a nikkor 80-200 f2.8.
HOWEVER, I found out that mated with the "right" lens, the filter can be consistently sharp at all apertures. In my case a 50mm f1.4 is sharp with the a vari-nd at all apertures and at different filter power settings.
For those interested here are the tests with color and resolution charts. And for those interested, how to DIY it.
Ted Ramasola
http://ramasolaproductions.com
Old November 5th, 2012, 09:58 PM   #52
Hi Ted,
I wonder why the longer focal lengths are so adversely affected? Does this happen with the up market versions?
Old November 5th, 2012, 11:26 PM   #53
Hi Alastair,
I recalled back I saw a shootout done with some brands, if my memory serves me right, they compared the Singh ray and LCW and it showed loss of sharpness with long lenses. I just can't recall which. The heliopan apparently is sharp and useful with several lens types. I have no personal experience with that so maybe someone who tried it can chime in.
On a side note, I use the mosaic VAF-5D2, and it does the opposite! The longer focal lengths are ok but on the wide end its picky with certain models.
Ted Ramasola
Ted Ramasola is offline   Reply
