#46 |
Re: Fader ND filters - Any recommendations?
I have the light craft workshop and really don't like how it degrade the image. Anybody use Tiffen here and can comment on them?
#47 |
I've been using the Fader ND Mk II for a while and recently started using the newer Digi Pro-HD version.
Built quality is better and it's overall easier to handle. It still gets a bit soft when on telephoto lenses but more common focal lengths it should work great. Here's a review we did of it recently (Click CC for English subtitles) |
#48 |
I bought a Fader ND way back because I baulked at the asking price for the Shing Ray. It is garbage at anything past its half way setting, causing uneven vigetting, and a pronounced, but also uneven colour cast. I never ever use it, but my concience won't let me pass on such a lemon to anyone else.
So I now use Formatt Hitech 100mm resin filters, but besides a set of three GNDs, I only have the eight stop ND with gaskit, and it works flawlessly. To look through it is like a welding mask, but its effect is completely even across the frame, and there is no noticable colour cast.
Stills at: www.flickr.com/photos/trevor-dennis/ |
#49 |
Below are two pictures, the first was taken through a Fotga “Slim wide band FADER ND design for digital camera” variable density filter and the other through a Hoya UV(0) filter that I use as a lens protector. The Fotga is about $20 au including postage.
To eliminate camera movement as far as possible the Nikon D300 was tripod mounted and used in mirror up mode. The lens used was a 300 mm f4 Nikkor and the camera was set in aperture priority mode (f 5.6). The camera set the exposure that varied over an 8 fold range. I used the full range of Fotga settings and the results were all very similar, i.e. no better or no worse anywhere over the full range. Apart from the results l Iike everything else about the Fotga. I would be interested in seeing the results from more upmarket filters. http://www.dvinfo.net/forum/images/a...attach/jpg.gif |
#50 |
I purchased a bunch of these filters and tested them on a GH2. The overall winner for me was the Fader HD. It is their most expensive and is made for video use. It has a two stop difference over the Heliopan.
#51 | |
HOWEVER, I found out that mated with the "right" lens, the filter can be consistently sharp at all apertures. In my case a 50mm f1.4 is sharp with the a vari-nd at all apertures and at different filter power settings. For those interested here are the tests with color and resolution charts. And for those interested, how to DIY it. |
#52 |
Hi Ted,
I wonder why the longer focal lengths are so adversely affected? Does this happen with the up market versions? |
#53 |
Hi Alastair,
I recalled back I saw a shootout done with some brands, if my memory serves me right, they compared the Singh ray and LCW and it showed loss of sharpness with long lenses. I just can't recall which. The heliopan apparently is sharp and useful with several lens types. I have no personal experience with that so maybe someone who tried it can chime in. On a side note, I use the mosaic VAF-5D2, and it does the opposite! The longer focal lengths are ok but on the wide end its picky with certain models. |
