7d with FCP 5.1.4? at DVinfo.net
Canon EOS Crop Sensor for HD
Old August 10th, 2010, 12:36 PM   #1
7d with FCP 5.1.4?
Before I do the mpeg Streamclip to Pro Res flow, can anyone tell me if this will work on my ancient FCP set-up?
Jim Morlino is offline   Reply With Quote
Old August 10th, 2010, 03:03 PM   #2
FCP5 doesn't support ProRes.
Old August 10th, 2010, 03:41 PM   #3
Shaun, thanks - as I suspected, but I went ahead and downloaded MPEG Streamclip anyway - but ProRes doesn't show up in the list of "Export as" - what gives?
Old August 10th, 2010, 03:47 PM   #4
The ProRes codec comes with FCP6.
Writer-Director-DOP
www.liamhall.net
Old August 10th, 2010, 04:46 PM   #5
Liam, I was talking about MPEG Streamclip. I downloaded the app, opened a 7d clip, and there seemed to be no option for ProRes
Old August 10th, 2010, 04:57 PM   #6
Liam is correct - the CODEC comes with FCP6. MPEGSC can't encode to something if it doesn't have the full codec available (not just the playback component which is available for download)
Old August 10th, 2010, 05:33 PM   #7
Ah...I see. So after I upgrade FCP, the functionality of Streamclip expands to include ProRes?
Thank you!
Old August 10th, 2010, 05:44 PM   #8
If you use MPEGStream Clip on the computer you installed FCP 6 yes. Also you might be able to use Canon's plug in for FCP as well depending on the computer you are using (intel yes G5 not sure)
Canon Digital Learning Center - Introducing EOS Movie Plugin-E1 for Final Cut Pro
Old August 10th, 2010, 06:35 PM   #9
The Canon plugin requires FCP 6 or 7, likely because Canon does not provide the Prores codec.
Kevin Wolff is offline   Reply
