Only getting B&W from composite out
I've connected the composite video out cable to two different monitors and I only get a B&W image. I've searched the manual and menu settings. Is something set wrong or is something wrong with my 7D? Thanks.
I have no idea why it corrected itself. But it's working as it should now.
It's probably the cable.
Pal/NTSC mixup ?
color is coded diferently in the two system. |
#5 |
No mix up. It's working fine now. I don't plan on using it much more anyway. Abel Cine has a battery powered HDMI to SDI converter I'm going to buy so I can use my SDI field monitor.
