Exposure Shift Even in Full Manual? - Page 2 at DVinfo.net
Canon EOS Crop Sensor for HD
Old July 22nd, 2010, 07:40 PM   #16
Here's the link to the new firmware update which should fix the issue:
Canon EOS 7D Firmware Update
Black Label Films
www.blacklabelweddingfilms.com
Travis Cossel is offline   Reply With Quote
Old July 22nd, 2010, 09:13 PM   #17
Hey Trav,
Did it fix the issue for you? I'm going to upload it to my cam in a bit and test if it gets rid of the split second overexposure in my clips when I first hit record, which happens randomly.
Randy Panado is offline   Reply With Quote
Old July 23rd, 2010, 09:30 AM   #18
Don't know yet. I just updated the cameras last night. I have a shoot in 30 minutes so we'll see. The issue is intermittent, so it's going to be hard to know if it got fixed or not right away.
Black Label Films
Old July 25th, 2010, 07:16 PM   #19
Originally Posted by Bill Engeler View Post
I think the lightening is due to the sun reflecting off the building straight into the lens. I see a hot spot that gets brighter as you dolly into the end position. The flare is causing a slight loss of contrast.
Bill is correct.
Lance Watts is offline   Reply With Quote
Old July 28th, 2010, 03:37 PM   #20
Bill is not correct, and I've already explained why. It was a good guess but it is incorrect.
I've had this exposure shifting happen in other situations where the camera was locked down static. I had a shot of some wedding programs with nothing but blue sky in the background and I shot a timelapse (just ran video). For no reason, after a minute or two, the sky lightened. I had another timelapse of a sunset and as the sun had nearly set the sky suddenly lightens. I also had an indoor static shot of a groom buttoning his jacket and the exposure of the scene lightened just slightly for no reason.
The fact that there is a firmware update addressing the problem (and hopefully fixing it) shows that this is not simply an issue of a change in light entering the camera.
Black Label Films
Old July 29th, 2010, 01:03 PM   #21
Still no manual audio. WTF Canon!
Brett Munoz is offline   Reply
