Video out at DVinfo.net
Canon EOS Crop Sensor for HD
Old June 27th, 2010, 03:02 PM   #1
Video out
Does the T2i have any form of video out for monitoring during recording?
Thanks, Craig
Craig Hollenback is offline   Reply With Quote
Old June 27th, 2010, 05:26 PM   #2
Yes. I believe it has an hdmi output.
Cole Seidl is offline   Reply With Quote
Old June 27th, 2010, 07:46 PM   #3
The HDMI output is HD resolution during monitoring, but switches to SD resolution during recording.
Richard
Richard Hunter is offline   Reply With Quote
Old June 28th, 2010, 07:30 PM   #4
cheap composite?
Anyone know of a cheap HDMI to composite adapter?
Old June 29th, 2010, 12:10 PM   #5
Doesn't the T2i have composite out too? The 5D2 has an AV output via a 1/8" TRRS jack. The 7D's AV output is via a proprietary connector. Is this feature missing on the T2i?
Jon Fairhurst
Old June 30th, 2010, 04:15 AM   #6
No it's not missing... I believe it's the same as the 7D (although I'm not sure, I've never used a 7D).
The T2i has a composite output, but it uses a mini-USB to component RCA cable (comes in the box). You can't use the composite out and the camera's LCD at the same time though.
Aaron Fowler
PMW-EX1 / EOS 60D / EOS 550D / FCS2 / CS4 PP
Aaron Fowler is offline   Reply
