#16 |
I'm not sure if the glass is the best, but it's a contender. I would say that the metal around the glass and the focus rings are probably the best. Especially if you rent a CP.2 kit. :)
Jon Fairhurst |
#17 |
I'd get the Canon EF-S 17-55mm IS. I got my 7D with the kit lens and sold the kit lens. I also got the Tamron zoom, and image wise it was fine but for me the manual focusing was tricky because of the very short throw of the ring so I returned it and purchased the $400 more expensive Canon. The Canon is easier to focus and in my opinion has slightly better glass.
I've also gotten a Tamron superzoom lens, the 18-270mm IS for the 7D. It's got an amazing range, but seems noticeably softer and when zooming, even if you have it set to a high F-stop, the exposure still clicks on the zoom - annoying. But 270mm for such a compact lens is pretty amazing. But the faster zooms like the Canon 17-55 and the 70-200 2.8 are very nice, quality (and expensive) lenses. I also have a few Sigma primes, and I like them a lot, the 50mm and the 30mm 1.4. They have a nice solid feel to the focus rings. I don't hear a lot of people talking about them but they look good to me. A sleeper for a 85mm is the Rokinon, and it is actually a very inexpensive lens but good glass. I also have the Tokina 11-16mm 2.8mm and that one is nice because you can actually use it at 16mm on a 5D as well. I used to use protective filters over my lenses but I stopped. I found they were actually degrading the image and adding another variable to the process. I make sure I have a hard hood on to protect the lens from crashing into something. I do use the Fader ND, especially outdoors. So many lenses, so little time... Good luck! |
#18 |
edited edited
#19 |
+1 on Canon EF-S 17-55mm IS. Awesome images, the lens stays on my 7D most of the time.
Also I think no-one mentioned this fantastic wide lens: I own it, and it is a great lens with low distortion. Pleasure for architectural or otherwise wide shots. Wide enough for most situations even on 7D's APS-C sensor. |
#20 |
I recently bought a 7D and I've been using it to shoot TV commercials. I had the luxury of renting 5Ds and 7Ds with various lens packages before I decided on my purchase. I went with the 7 over the 5 mainly because the way I operate, mostly hand held, no shoulder rig, I was getting more more noticeable rolling shutter issues with the 5. The other, less important reason, is that I Iike to do my own focus and it's just enough harder with the 5 to make a difference for me. (I know, you can stop down and up the ISO, but it's always been my preference to shoot at between F 2 and 2.8, when possible). To my eye, I get better results with prime lenses over zooms. I love the Canon L series, but they are costly and I also really like the look I get with Nikon manual focus lenses. They are cheap enough, even with adapters, so you can build up a decent collection for just a little more than the cost of one L lens. In spite of my prejudice against zooms, I just ordered the 17-55 2.8 Canon to use for day exteriors. I have not tried it yet, so I can't comment, but lens changes were slowing me down and I was worrying that opening the camera so much out in the field was risking getting dirt on the sensor. As for NDs I use Tiffen (cheap and I've been using them for years on big budget commercials with few issues) ND .09s which drop the exposure down 3 stops. I'd probably use .06s too, if I had them, but so far the 9s have been sufficient.
#21 |
Here's a major advantage of 7D vs 5D for video: 7D outputs HD signal out HDMI for monitoring during recording.
5D however drops the output resolution to SD, making it impossible to use external monitors (I have a 7" one) for focusing. |
