Sandisk Firewire Reader Not recognized on Laptop: Help at DVinfo.net
Canon EOS Crop Sensor for HD
Old May 29th, 2010, 10:12 AM   #1
Hi guys,
I need your help. I have a laptop PC with 4pin firewire, and a sandisk firewire reader (6pin).
I connected it to an adapter 6-4pin adapter, but it doenst power on the sandisk firewire reader.
Do you have any suggestions how to make it work? I really need it for my SDE I thought I would be able to transfer files with firewire. I read that only Mac has this capability.
thanks,
Bay Area Wedding Videographerwww.reb6studios.com
Sigmund Reboquio is offline   Reply With Quote
Old May 29th, 2010, 10:34 AM   #2
I have a cheap little Lexar Firewire and both stills and video come into - my Mac - very fast vs USB 2.0. Sorry, I do not have a clue how PCs work...
Yet, and maybe it's different over there, but when I hear 4pin-to-6pin adaptor I automatically think incompatible. Good luck with a workaround.
Jim
Jim Cancil is offline   Reply With Quote
Old May 29th, 2010, 12:25 PM   #3
Originally Posted by Sigmund Reboquio View Post
Hi guys,
thanks,
Four pin firewire ports do not provide power to the attached devices. Replace the four pin port with a 6 pin. Or get a Mac.
"An expert is a man who has made all the mistakes which can be made in a very narrow field." - Neils Bohr
Carl Rubin is offline   Reply With Quote
Old May 29th, 2010, 06:18 PM   #4
Most 6 pin firewire readers are not compatible with 4 pin firewire ports. 9 pin firewire readers are not compatible with 4 or 6 pin firewire ports. You should be able to buy a 6 or 9 pin firewire pc card, but I suggest going with a 9 pin firewire pc card.
Canon 7D w/grip | Speedlite 580ex II & 420ex
EF 16-35mm f/2.8L | EF 24-70mm f/2.8L | EF 85mm f/1.8 | EF 100mm f/2.8 macro
Ed Cubillan is offline   Reply With Quote
Old May 29th, 2010, 08:21 PM   #5
Images: 18
Hi Sigmund.................
Er, what capability would that be, then?
Firewire? Nope, think again.
I would suggest you find a machine (any machine) that has 6 pin firewire, transfer your files to it and use optical media to get it to where you want it to go.
CS
Old May 30th, 2010, 12:34 AM   #6
That depends on what you mean by Mac, I think it only works with an iPhone running iTunes 9.0...
Chuck Spaulding is offline   Reply With Quote
Old May 30th, 2010, 06:40 PM   #7
As I mentioned, just get a firewire PC card for your laptop. Just search for Firewire 800.
Newegg.com - firewire 800 expresscard
Even though you need firewire port with 6 pins (firewire 400), I would go with a firewire 800, which uses 9 pins. This way, if you decide to get a faster reader, you won't have the same problems again.
