h264 back into the camera ... at DVinfo.net
Canon EOS Crop Sensor for HD
Old May 4th, 2010, 02:46 PM   #1
Hi,
Is there anyone who tried to put an edited clip back into the camera?
I guess the real question is: is it picky as to what type of h264 you can playback?
François
Francois Lacasse is offline   Reply With Quote
Old May 4th, 2010, 03:00 PM   #2
I don't think so...
there's an associated .thm file. Without this file the camera sees "No Image"
So, why would you want to do this?
Rusty
Rusty Rogers | Films
Rusty Rogers is offline   Reply With Quote
Old May 4th, 2010, 09:41 PM   #3
Thanks for the reply Rusty,
It would of been nice to use it as a playback device.
I switched from an HV20 (when I had a project done, I could put it back to tape)
Now, how can I view a finished project in HD on a TV?
Hmmmm ...
Old May 5th, 2010, 04:58 AM   #4
Get something like a WDTV player if you want a portable player to play back the files on.
Jonathan Palfrey is offline   Reply With Quote
Old May 5th, 2010, 08:17 AM   #5
Thanks for the cue Jonathan ... I'll look it up!
Old May 6th, 2010, 06:28 AM   #6
I wish someone could figure out a way to play back files created outside the camera in the camera. I really wanted to play some color bars so I could check the LCD display for color/brightness accuracy.
I tried tricking the camera into playing back a file named as if it was created in-camera and even renamed an existing .THM... no dice.
Jeff Krepner is offline   Reply With Quote
Old May 10th, 2010, 09:10 AM   #7
Yes, the .THM (thumbnail) is also a JPEG, but specifically it contains EXIF data relating to the .MOV file. I would guess that editing the EXIF data in the .THM would do the trick, but I'll let you know once I get around to playing with this. I also think it would be a pretty cool feature to have.
If anyone else wants to have a go, here are some EXIF related tools:
EXIF editor
James Donnelly is offline   Reply
