0.5x Wide angle converter, not as wide as advertised...help! at DVinfo.net
Canon EOS Crop Sensor for HD
Old April 24th, 2010, 06:43 AM   #1
i used my 28mm lense, and took a picture at 28mm "without" the wide angle converter....when the wide angle converter is on, i took another picture at 34mm, and its the same...
therefore the 0.5x wide angle converter only opens me up 6mm, which is not .5x, its more like .2x...
its got a 1:1 macro on it that looks like it makes the 28-135mm lense a 22-135mm lense...
any thoughts? this is the lense below...
http://www.newworldvideodirect.com/p...productid=2796
EDIT:also took pictures with my 18-55mm lense and its noticably wider than the 28-135mm with the 0.5x wide angle converter lense, plus this converter is heavy as hell...lol
Corey Benoit is offline   Reply With Quote
Old April 24th, 2010, 07:17 PM   #2
The link seems to be dead, but I think I can guess. Unfortunately in the glass world you mostly get what you pay for, and probably what you have paid for is a fancy paperweight. But all is not lost. Remove the glass from the the macro so that you can still attach the lens to your camera without having to buy an adapter and your lens is as wide as advertised. Unfortunately it also becomes a textbook study of various types of aberration. You can use it as a novelty lens or possibly even in some limited situations where vignetting is part of the scene, like pointing into the interior of a car.
Rainer Listing is offline   Reply With Quote
Old April 25th, 2010, 05:40 AM   #3
fixed the link, its definitely wider, but not as much...if i remove the macro the lense and the adapter are far away and become blur image...
Old April 25th, 2010, 07:14 AM   #4
The information at the link states that the lens is designed for the Sony DSC-H7/9. These are cameras with much smaller sensors than a 7D, so they can use lenses with smaller covering power. Based on the ad, this lens isn't meant to work on a 7D, although it might anyway.
Peter Rhalter is offline   Reply With Quote
Old April 25th, 2010, 11:09 PM   #5
Checked the link, and sorry, from the price I hope I guessed wrong. At that price you are entitled to get something that works as expected. Perhaps you can get a refund.
Old April 27th, 2010, 12:28 AM   #6
That sort of adapter is not intended for use with SLR lenses. It is intended for use with camcorders with a fixed zoom lens that provides no wide angle view.
Return it for a refund if you can. If not, put it on ebay
Old April 29th, 2010, 05:45 AM   #7
which ones are made for the 7d?
