wave effect with wide angle lens at DVinfo.net
Canon EOS Crop Sensor for HD
Old April 11th, 2010, 07:35 PM   #1
This show on the travel channel, "Million Dollar Yachts", a lot of the cabin shots PAN through and there's this warping or wave effect during the pan. Question, is this going to happen at a particular mm? Is it hallmark of cheap glass? At what point (mm) do you get it?
Old April 11th, 2010, 08:08 PM   #2
the more distortion the lens has at wide angles, the more of a wave effect it will have during motion. It isn't pinned down to a particular mm, but dependent on quality of lens. Although doesn't immediately show cheap glass, because there is very expensive glass that does this as well, it would however indicate cheep glass if lens is not very wide.
Red Epic available for rent, starting at $500 per day, Scarlets, and Lenses available too. rentals.maddalenamedia.com
Louis Maddalena is offline   Reply With Quote
Old April 12th, 2010, 06:09 PM   #3
You can see this type of effect here, with a Canon 10 - 22mm WA zoom lens.
This was shot with a 550D rather than a 7D, but the 7D is the same crop factor so would give similar results.
Richard
Richard Hunter is offline   Reply With Quote
Old April 12th, 2010, 08:14 PM   #4
10-22
The video looks great! I just ordered the 10-22 and can't wait to see what I can do.
Alan Halfhill is offline   Reply With Quote
Old April 12th, 2010, 10:42 PM   #5
Personally, I like a wide look, but notsomuch during a pan which induces that bowing.
Old April 13th, 2010, 01:42 AM   #6
I agree Brian, but it was my first time out with this lens, and it looked so dramatic I couldn't help it! Next time I will try to exercise a bit more control.
Richard
