Twin Shoe Mount at DVinfo.net
Canon EOS Crop Sensor for HD
Old April 9th, 2010, 05:45 AM   #1
Twin Shoe Mount
What is everyone using when trying to mount more than one bit of external equipment to the top of the camera. In my situation I want to use a lamp and also an external mic at the same time....I'm sure there is something cheap out there but I'm struggling to find anything
Tim Davison is offline   Reply With Quote
Old April 9th, 2010, 05:54 AM   #2
You could use an off camera flash bracket, the type that screws to the bottom of the camera and gives a handle which has a shoe on it. That would give two mounting points with the cameras hot shoe plus a handle.
This for example: http://www.bhphotovideo.com/c/product/278249-REG/Manfrotto_233B_233B_Telescoping_Camera_Flash_Bracket.html
My Stock Video Blog
Linkedin
Norman Pogson is offline   Reply With Quote
Old April 9th, 2010, 09:02 AM   #3
Thanks Norman. That does appear pretty bulky, is there nothiong more simple out there. I would have thought that a simple attachment (with two shoe horn fittings) that screws into the current shoe mount would do the trick
Old April 9th, 2010, 09:08 AM   #4
Hi Tim, check this page - hope it's helpful. Specifically the Rycote mount.
VideoGuys Australia | Camera Brackets & Accessories
Stefan van Jaarsveld is offline   Reply With Quote
Old April 9th, 2010, 09:35 AM   #5
Contributor
How about the J-rod cube:
The J-CUBE-The best accessory mount for your HDSLR or compact video camera
Old April 9th, 2010, 03:36 PM   #6
Video Bracket
http://www.bhphotovideo.com/c/product/48520-REG/Sima_SLB_M_Video_Bracket_1.html
Pedanes Bol is offline   Reply With Quote
Old April 9th, 2010, 03:57 PM   #7
I just got one of these, a triple hotshoe support. I use it for my two Sennheiser radio receivers. If I like I can put the Zoom between them with a ball mount that I also have.
Creative Video Dedolight DLBSA-3S (DLBSA3S) triple shoe mount adapter, swingable latching
It can lean backwards or forwards if you like, or stay upright like in the photo.
Avey
theactionhouse.com
Wayne Avanson is offline   Reply
