Manfrotto 561bhdv Question - Page 3 at DVinfo.net
Canon EOS Crop Sensor for HD
Old August 16th, 2010, 08:39 AM   #31
Does anybody know what the difference between a 561B and 561BHDV is? Seems like the 561BHDV is the newer version but specwise there doesnt seem to be much difference
(found a new 561B for around half the price)
Manus Sweeney is offline   Reply With Quote
Old August 17th, 2010, 11:15 AM   #32
I have both and they are the same monopod. The side knob to control tilt-friction looks different but functions the same as well. The head, feet and post feel the same to me and I use them every weekend.
Raymond Tsang is offline   Reply With Quote
Old August 17th, 2010, 11:48 AM   #33
perfect thanks!
Old August 18th, 2010, 11:07 AM   #34
The heads are different. The 561bhdv looks like a 701hdv minus the fluid panning while the 561b looks like small 501 with a 577 adapter on the top. Like Raymond mentioned, their locking mechanisms are different. The 561bhdv has a one like a 501/503 type while the 561b has one like the 577 adapter.
Everything from the below the headis the same.
Randy Panado is offline   Reply With Quote
Old August 24th, 2010, 08:37 AM   #35
Pardon my ignorance, but could someone tell me what the benefit of the feet are? Is it just to be able to pan?
John Kopec is offline   Reply With Quote
Old August 24th, 2010, 08:40 AM   #36
The feet help stabilize it and makes it almost as sturdy as a tripod, but much easier to move. Add a fluyid head like a 501 and you've also got tilt and smoother panning.
Bruce Yarock
Bruce S. Yarock is offline   Reply With Quote
Old August 24th, 2010, 09:38 AM   #37
Yep. Without the feet, the monopod will slip like crazy at the worst possible moments. The difference is night and day.
Old August 24th, 2010, 11:25 AM   #38
Thanks guys!
Old August 31st, 2010, 09:52 AM   #39
Worth it without the 501?
If I can only afford the 561BHDV and not the 501 (or some other head), is it still worth it for shooting a wedding? We'll have two low-to-medium grade Manfrotto tripods and a Merlin for some eye-candy, but for my walkaround workhorse, will the 561BHDV (with a 7D mounted) suffice?
I've also considered renting a should-mount, but this thread and some other articles have convinced me this monopod is the way to go.
David Lavender is offline   Reply With Quote
Old August 31st, 2010, 09:55 AM   #40
Z-Finder necessary?
Also, 1 more question. It'll be an outdoor wedding in mid-afternoon (albeit early fall). I've been looking for an excuse to rent a Z-Finder. Would the 561BHDV + Z-Finder be a totally useless/awkward combo?
Old August 31st, 2010, 12:03 PM   #41
You don't need a 501 head. We've used the 561bhdv as-is and it works fine. Just spray some wd-40 on the ball base and it pans and tilts like butter :)
The z-finder is an invaluable tool and takes out alot of guessing when it comes to exposing and color in strong daylight. It's worth every penny.
The z-finder will also help with stabilizing your shots by adding an extra point of contact. We've eliminated one tripod due to this fact. Hope this helps David.
Old August 31st, 2010, 12:06 PM   #42
Hey Randy, you said you use a 501 head with your monopod? With the already fluid base of the monopod, are you still able to take advantage of the pan/tilt head?
Old August 31st, 2010, 12:41 PM   #43
Thanks, Raymond. I just needed a little nudge to go over the edge and make the purchase. I appreciate your input.
Old September 2nd, 2010, 10:25 AM   #44
Tilt lock/ ball joint lock on 561bhdv?
I just purchased the 561bhdv to use with my 7D for use in tight spaces and I wasn't expecting the monopod to tilt so easily (I guess I didn't do enough research!). Is there a way to lock the ball joint so that the monopod doesn't tilt so easily? Or, do you find that you can get steady footage holding the monopod? I did tighten the base using an allen wrench but that's about it so far. Thanks for your input!
Michael
Michael and Tricia Films
www.michaelandtriciafilms.com
Michael Curtis is offline   Reply With Quote
Old September 2nd, 2010, 11:19 AM   #45
Michael
Hey Michael - I'm the opposite as you. I try to get my base as loose as possible to allow for maximum flexibility of maneuvering, panning, dips, ect. For me at least, stability is achieved by keeping the camera close to the body; one hand on the focus ring and the other on the monopod handle.
Because the monopod comes shipped so stiff, we've loosened the joint and sprayed wd-40 on the ball to get it nice and smooth.
