slo mo
does the t2i record 60fps slo mo shots like the ex3 and others.because i really do shoot a lot of slo mo shots.
If you're referring to overcranking then that is not what it does but what you can do is shoot at 60fps and then conform it to 24p using Cinema tools and you would get a very nice slo-mo shot.
I have shot a slo-mo scene at the end of this clip using the above method: |
Lens ...
i know this is a bit unrelated, but I saw you shot the piece w/ a 1.4 and a 2.8 zoom. I have the 2.8 17-55 EF-S, but do shooting indoors often. How much of an improvement in light capture do you find with the 1.4?
p-films.com. Canon T2i f2.8 17-55, f1.4 50mm, Cool Lights LEDs |
In theory, an f/1.4 captures four times the light. It's significant under natural, indoor lighting. It can also be a bear to focus.
Jon Fairhurst |
#5 | |
XDCAM EX records that slowmotion for playback at 35mb/s MPEG2 while the T2i will record at 45mb/s and effectively playback slow motion (after converted) will be 18mb/s* H.264 at 24fps. So in short, no it doesn't record slow motion like the EX3, but it does have the capacity to do slow motion once post processed. *(45 x 24/60 = 18mb/s)
Aaron Fowler PMW-EX1 / EOS 60D / EOS 550D / FCS2 / CS4 PP |
#6 |
i use adobecs3 to edit so can someone tell me how it works with this application?i mean conforming and all that.please just explain the process.thanks
