#46 |
If it's not full res, it should look different on the screen. slightly soft. As for other programs, Powerdirector can do it as can Edius NeoBooster2. Full Edius should have it shortly.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
#47 |
sync issuie with T2i and Cineform
As recommened I downloaded Cineform, for my T2i footage I use Vegas 9 64 bit and Windows 7 64 bit. All the intermediates it created have an auido synce issue. Any ideas?
#48 |
DVfilm has a inexpensive plugin for Vegas Pro users that transforms the raw QT movies from the camera into easy to edit proxies, and then when its time for output, you render from the original file. And all this is done automatically, behind the scenes.
Epic I by DVFilm - Edit DSLR H.264 Quicktimes from Canon 5d, Canon 7d, or Canon Rebel in real time with Sony Vegas Pro 9.0 I am trying it out tonight. |
#49 |
Interesting, please let me know how it works out.
#50 |
Clips played from Pinnacle timeline look exactly like same clips played from Quicktime - seems full rez to me. I usually can look at edits in full rez, full screen - very nice, not some low-rez version.
#51 |
A little problem during the install (user error) but I got it up and running and it works well. $45 doesn't break the bank- its the cheapest accessory I've bought for the 550d so far.
My only gripe is that the plugin runs on your computer all the time unless you shut it down from the taskbar. It really should only activate and run when Vegas is running. I hope they fix that in their first update. And I do think there should be a video tutorial on its use, it would get people up and running quick and cut down on support requests. |
#52 |
I have this old computer from 2004 which has worked well for cutting DV.
But now with my 550d, how much would a computer (PC) cost me to be able to cut the material (converted to a better format) in full HD without lag or hickups? And being able to use two monitors. An averageprice? $1500? |
#53 | |
#54 | |
Spend the money now, get he performance to gain time to pay for the upgrade. Go cheap, pay in time wasted to render. I think $1500 is cutting yourself way too short. It's painful to think in the $3-$4K range, but that's what you need to consider. I was in the same boat a couple of months back an have no regrets spending the extra cash. RT edits and 6x render speeds mean you move to the next project faster. The day you forget conversion (just to start editing) is the day your new pc pays for itself. |
#55 | |
Thanks in advance! |
#56 |
I saw that, but I find since several of my plugin don't have 64 bit yet, and the fact that you can't preview on capture with the 64 bit, I find myself using the 32bit more anwyay. So this wouldn't be a big deal for me, let us know Ed? Thanks in advance!
#57 |
#58 | |
I nedd a computer for A) edit 550d footage in full HD in Premier Pro for shorter projects (shoter than 10min) and I need it for B) "animate" in Premier Pro using still images, layers and effects (Example: YouTube - The Man Who Wanted To Die) in full HD. Would a 1500dollar comp work for that but with rendering or will the editing be laggy and the playback not flow? Rendering is not my main concern but not having fluid playback etc would suck. I render animation etc in PAL (720x576) on my current computer (p4 2.4ghz, 4gig RAm, ATI Radeon 9600) and don't find it "to" painfull - but as seen that computer will not work at all with cutting 550d fottage or "animate" in full HD :/ |
#59 | |
Colin |
#60 | |
The demo only does 5 second clips- so shoot a couple small 5 sec clips and test it out before you buy. |
