#16 | |||
When I told the local PBS producer I had a show I was putting together for them, and asked if their specs had changed after the digital switchover, she said no. Just follow Red Book. Simple as that. My EX1 passes for SD delivery and that is exactly what I am going to hand them. Unless I can get a NanoFlash in time and get a passable HD signal. Quote:
Maybe you're right. Maybe the engineers at PBS and other broadcast stations don't know their business and can't tell. Maybe that $200k of gear they have in the room is just for looks. Hell, what do I know. Maybe I could just slip it by them. They probably won't notice.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
#17 | |
I'll have to get clarification on whether the 5D/7D will pass muster for HD broadcast. But since the published Red Book hasn't changed since 2007, I am going to bet no.
#18 | |
Barry Wan Kenobi
And my results correspond pretty much identically with those at dpreview. So I don't know what DxO is doing differently. They got 10 stops of dynamic range out of a GH1, whereas I got 8.3. I don't know what their methodology is or how they're arriving at the different results. |
#19 |
Thanks Barry!
According dpReview all DSLRs are quite close in Dinamic Range at ISO 200: - Nikon D300s usable range - 8.4, - Canon 5D Mark II - 8.4, - Pentax K-7 - 8.4, - Canon 7D - 8.3, - Lumix GH1 - 7.7. Of course I wonder what the dynamic range would show EX1 on their methodology? Probably no one will answer this question. |
#20 | ||
Also, the bureaucrats at PBS are not the only people who know how to use a waveform and vector scope, in fact I have a couple of those and a 50" calibrated monitor and I know how to use them. And yes there are plenty of PBS stations that have $200K of worthless SD equipment. KQED wanted a BetaSP for the distribution of a project I produced for the Pacific Mountain Network. I had to go to the local broadcast museum to rent one. |
#21 |
I would call it narrative too in the sense that Mr. Bloom had 100% discretion over which shot to use -- and presumably Perrone's point is that in a documentary you're often beholden to a particular "Live" event as it unfolds. If moire or some other unwanted artifact pops up you're stuck with it. Bloom can choose the perfect shot, but the guy filming a SEAL raid in Somalia is "In the moment" of a dynamic situation and has zero control with just moments to capture the story.
#22 |
There are all kinds of documentaries and different ways to shoot them. Sure there are times when you have little or no immediate control over a situation, but rarely, if ever, have I not had the opportunity to go to get B-roll footage were I did have "enough" discretion over the shots I thought I needed.
On many of the shots at the Ranch, Philip got to choose the lens and he had a tripod, it didn't appear that he had much more than that. He also had to meet, and work with several people to demonstrate the capabilities of these camera's, its not like they hired him to simply photograph the ranch. I'm sure there was plenty of hospitality but I'm guessing he was pretty busy while he was there and might not of had as much "discretion" as you might think. I'm not sure its mutually exclusive but I'd characterize that shoot more like a documentary than a narrative. None of this matters, Perrone's point was that the 7D doesn't "measure up," it doesn't meet PBS's standards. Well I guess that depends on who's doing the shooting and who's doing the measuring. I get the impression from Philip's blog, and what I can see for myself, that he and others don't share that opinion. |
#23 | |
Most cockpit material shouldn't expose too many of the DSLR weaknesses. In the past, 16mm cameras have been used to shoot aerial or with the old gun cameras on specialised mounts to be cut with 35mm footage. |
#24 | |
I hate it when people are such fanboys of Nikon over Canon or PC over Apple, it is stupid. I see your point and have limited knowledge on this subject. I was simply engaging it to continue my learning. |
#25 | ||
Red Book . Key Deliverables . PBS Online Web Site | PBS The Section that pertains to Video quality is quoted below for convenience of the readers. Note that I will have to try to get an exception for the EX1 also (added emphasis is mine): Quote:
#26 |
Scratch the Red One from PBS as it's not 3 chip and not CCD. Who writes this stuff!
#27 |
Great! That is funny.
#28 |
The info PDF I found on the site is dated 2007, which is pre RED One.
The BBC specs sheets do get up dated, but I suspect the current DSLRs would be counted as SD same as HDV and Super 16. |
#29 |
All the broadcasters in the UK have similar specifications when they are commissioning.
http://www.gooderick.com |
#30 |
Our local PBS station (KOPB) gives so many bits to the alternate SD channels that "HD" is a joke. Every scene change looks like a mosaic wipe.
I guess Frontline never read the Red Book... High Definition War Footage Taken with Canon 5D Mark II - Obama's War - Gizmodo Still, while I really like the 5D2, no way is it the best cam for every situation. It rocks for narrative on a budget though.
Jon Fairhurst |
