24-70 Canon on glidecam at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 11th, 2009, 01:07 PM   #1
Has anyone flown the 7D with the 24-70mm on a glidecam. I'm looking to get a wide angle lens and I'm not sure if I should get the 24 1.4 or the 24-70 2.8.
Jason LeFrense is offline   Reply With Quote
Old December 11th, 2009, 01:29 PM   #2
24mm is actualy 38mm on the 7D, not that wide, if you want wide, Tokina 11-16mm 2.8 is wide.
Khoi Pham
www.proeditproductions.com
Khoi Pham is offline   Reply With Quote
Old December 11th, 2009, 06:07 PM   #3
I would definitely recommend going wider than 24mm. The Canon 14mm f/2.8L would be ideal.
Canon 5D Mark II || L-Series Lenses || Steadicam Pilot || Final Cut Studio
www.lovestorymedia.com
Erik Andersen is offline   Reply With Quote
Old December 11th, 2009, 07:44 PM   #4
Thanks guys I will check it out for sure.
