Building a rig at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 8th, 2009, 02:58 PM   #1
Building a rig
Hi,
Im going to build my own railsystem and have been doing some research on this. I want to buy a readymade followfocus system so I need it to fit whenever that is added later on.
I think that the standard measurements of a rail setup is 15mm rods with 60mm spacing.
Im not sure if that means that it is measured from the center of each rod or the gap between them.
I would be very happy if any rig-owners could check and verify the measurements on your particular rig.
Thanks.
Viktor
Canon EOS 7D, Canon XM2, MA-300, Azden SGM-1x
Viktor Carlquist is offline   Reply With Quote
Old December 8th, 2009, 04:13 PM   #2
it is 60mm center to center
Cody Dulock is offline   Reply With Quote
Old December 8th, 2009, 04:54 PM   #3
I built a simple rails system for my 7D for around $50 plus QR plates.
It's designed to be modular so you can go from your monopod, tripod, dolly etc.
Nigel Walker is offline   Reply With Quote
Old December 9th, 2009, 02:04 AM   #4
Thanks Cody!
Nigel that rig looks super! Those pictures are realy inspiring. :-) I will probably use aluminium rods on mine.
