77mm Fader ND Filter - Page 2 at DVinfo.net
Canon EOS Crop Sensor for HD
Old December 2nd, 2009, 11:28 AM   #16
Originally Posted by Nigel Barker View Post
The 77mm Fader ND is basically an 82mm filter in a 77mm step-down ring so I would be amazed if there was any vignetting with the 1.6X crop of the 7D.
Does that mean if I have a 77mm lens and get the 77mm Fader ND, will the original 77mm lens cap work still? Or would I have to get a 82mm lens cap to cover the 77mm Fader ND?
Lloyd Ubshura is offline   Reply With Quote
Old December 2nd, 2009, 02:03 PM   #17
I also purchased a circular and linear polarizer and don't understand why anyone would purchase these more expensive ones, they are the same thing only thinner
www.insectula.com
Mike Peterson is offline   Reply With Quote
Old December 2nd, 2009, 05:42 PM   #18
Sorry for the dumb question, but how are they the same as a adjustable ND filter? I didn't think you could adjust a circular or linear polalizer.
Old December 2nd, 2009, 06:05 PM   #19
A 82mm lens cap was included with my Fader ND. Just FYI.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old December 2nd, 2009, 10:14 PM   #20
Mike I'd like to learn more about what your suggesting. Are you saying that if you use a circular polarizer along with a linear polarizer it becomes and adjustable polarizer?
If so about how many stops do you gain?
Also if that's the case what and where could I find such a thing?
Chuck Spaulding is offline   Reply With Quote
Old December 2nd, 2009, 11:32 PM   #21
Hi Lloyd. Yes you can adjust a CP filter. It is in 2 parts, one screwed to the lens and one on the front that is turned to change the filtering effect.
Richard
Richard Hunter is offline   Reply With Quote
Old December 3rd, 2009, 12:15 AM   #22
A polarizer and an ND are two totally different filters that do totally different things. It just so happens that one side effect of the polarizers is light loss.
Graham King is offline   Reply With Quote
Old December 3rd, 2009, 02:49 AM   #23
Mike, I think you answered your own question. The Fader is thinner, hence you can actually use it on wide lenses without vignetting. Also the faders are actually cheaper than most Cpl and LP combinations.
Graham,
A variable ND IS two Circular Polarisers back to back, that's how it works to give the ND effect.
Dan
Old December 3rd, 2009, 03:02 AM   #24
I bought the Singh-Ray 77mm and got step rings to fit my other lenses. It works well and I'm totally happy with it.
Bruce Yarock
Bruce S. Yarock is offline   Reply With Quote
Old December 3rd, 2009, 03:03 AM   #25
Oh cr*p, I did not know that. So with any vari ND, you may or may not also be getting the effect of polarization as well depending on the current amount of rotation?
Old December 3rd, 2009, 07:40 AM   #26
Buy a linear polarizer and a circular polarizer. Screw the circular one on to the linear one. Mount both to your lens. Turn the outer ring of the circular polarizer...waalaaa! A fader ND. There are many brands to chose from but I got my two from B&H for under $100.
Paul Frederick is offline   Reply With Quote
Old December 13th, 2009, 04:43 AM   #27
The 77mm version of the Fader ND is under $110 including shipping so you don't make much of a saving & purpose made variable density filter is thinner, more convenient & works better. The 58mm Fader ND is around $65 including shipping. The combination of two polarisers is still cheaper than the over-priced Singh Ray variable density filter & you do of course get a couple of polarising filters to use standalone. I bought a a CPL & LPL cheap from Ebay when the only option was that or the $400+ for the Singh Ray but now the Fader NDs are available at reasonable prices it's really not worth bothering with a DIY job.
Old December 13th, 2009, 04:48 PM   #28
I have the Fader brand and it seems well made and high quality, though I haven't used it much yet. Is it inferior in any way to the Singh-Ray?
Keith Moreau is offline   Reply With Quote
Old December 13th, 2009, 09:45 PM   #29
I bought the circular and linear polarizer slightly bigger than my biggest lens. I bought step up rings for all my lens sizes. No vignetting. Cheap. Work as well as the expensive variable NDs but a bit thicker. Saving $70 - 300 for a little thicker filter.
No brainer.
www.insectula.com
Old December 25th, 2009, 02:41 PM   #30
I've got 3 ND 77mm filters for my 10-22 (4x,8x,400x) at 10mm you can only use one (removing the UV filter) if you zoom in a little (like 12mm) you can stack 2. Going over those numbers will get you visible vignetting. I've also got a 77-72 and a 77-62 adaptater to use it on other lenses.
The best tip I can give you is : keep them the cleanest you can. You will likekely use them with small apertures and long exposure, so any spot will be noticeable. I use only dry microfiber cloth.
Jacky Hicks is offline   Reply
