#16 | |
#17 |
Depends on the lens just like your typical pro video camera. With the right lens you can back focus. With the kit lens just like most handy cams there is no back focus... You are dependent on auto focus. It's not the camera it's the lens that is on the camera.
#18 |
What I find works is to turn on the histogram function for still pictures, which shows the histogram with the still image review (I have upped playback time to 4 seconds). I just click a picture before starting a video to look at the histogram. I also turn on the function that makes overexposed areas blink on the still-picture review screen, which is somewhat similar to zebra.
I find that if I use the 7D LiveView as a monitor (without the histogram function above), it tends to overexpose slightly, so I typically close it down a little more than the display would suggest to get the exposure I like. I'd like to get a zebra function on this thing! |
#19 |
Hi Roger
What's the advantage of taking a picture and using playback as opposed to just being in still mode, hitting the 'info' button until you see the histogram, and then switching over to the video mode and taking the video? |
#20 | |
#21 |
I don't know of any photo lenses that allow for back focusing. You have to remember, these aren't video lenses where you would normally need to back focus at all to pull off a push in or pull. And, of course, there would be no back focus on the body. It's the lens that has a back focus.
#22 | |
I'm able to get a histogram in movie mode with a single button press (shutter), which is very fast. I don't have to press play or switch back an forth from still to movie or anything. After the shutter button is pressed in movie mode the camera "reviews" the still image taken with histogram automatically, if you have selected it to display histogram during review in menu options. I have it set up so that after any still picture is taken in any mode, the display shows the picture on the left, histogram on the right for 4 seconds before reverting back to whatever capture mode I started in. Also if something starts to happen on the scene I can just press the "start" button and the camera instantly aborts the image review and starts capturing video. I find this the most nimble way to get exposure feedback on the camera in its current configuration but I'd prefer to have Zebra or the histogram live on the LCD at all times. As I read you response I took out my camera, put it in still mode, and pressed "info" several times but a histogram never appeared without taking a picture. I'd like to use that feature for stills if I can figure out how to get it hold on the histogram. Time to go back to the manual! Last edited by Roger Shealy; November 5th, 2009 at 12:32 PM. |
#23 | |
#24 | |
Thanks for the explanation. It sounds like a good mode. I had to fiddle with it to get the histogram to show up. Just like the live mode, you have to hit the info button a few times to get the right information set to display during the review period. Once it's set, it's sticky. I was trying for a while and nothing ever showed up until I re-read the manual. However, though it's useful, and I'll have to use it real world situations, I think I prefer to check out the histogram in still mode first, in live mode and adjust the histogram for proper exposure real time, using ISO, aperture, shutter speed, and Fader ND, then switch over to movie mode once I'm satisfied. I chose the RGB histogram, as I like to see the relative levels of each color to see if I'm too hot or dark on a particular color. It's a histogram mode I wish my Sony EX1 camcorder had (it's just total brightness histogram). With your method I'd have to make a change, take a picture, make another change, take a picture, which could be time consuming. With my method I can make changes real time, then flip over. Your mode, though, does have usefulness I think it would good if I'm in video mode and I just want to do a quick sanity check. Thanks for the hint! Keep them coming! |
#25 |
Keith,
Let's keep building on these ideas. I can see a use for both. I'm going to try using the RGB Histogram, which I have no experience using. It sounds very useful though. Thanks for your explanation. |
#26 | |||
For white clipping is really easy. Just use highlight alert ON. Quote:
#27 |
I don't really use histograms much myself either, but I wouldn't agree that getting a "good reading" in the histogram will result in a boring or flat image. This may be true if you are working with a predominantly dark scene for instance, you wouldn't want to drive the values up to the middle arbitrarily, but if the frame contains a full range of values it will return a full-looking histogram without resulting in a flat image. Shifting exposure will result in the histogram moving right and left; adjusting contrast or dynamic range would appear to squeeze or unsqueeze the histogram towards the center.
Focus magnification is only useful when the subject or camera is not moving, before the shot. If either happens (as things tend to when shooting motion pictures!), most will be pulling focus by eye and as I said earlier, on longer lenses and open apertures, this is not easy even for seasoned veterans.
Charles Papert www.charlespapert.com |
#28 |
Starway Pictures
This is exactly the method I've started using on my 7D as well. Pretty reliable.
#29 | |||
#30 |
