how can you shoot with fixed LCD?
Hello,
I am thinking of buying a HDSLR for the full HD video capability. I was looking at the GH1, because all canon's lack the flexible lcd. I have been shooting with camcorders (vixia series) and cannot live without the lcd. Never use viewfinder. I was very disappointed that canon again comes in the 7d with a fixed lcd. In the announcements I read that it has a good viewing angle and contrast, but I doubt that it will be enough for me. I film insects in bright day-light and usually low to the ground. Are some of you filming under the same conditions with the 7d or with the 5d mark 2? What is the actual viewing angle by which you can still judge the sharpness of the picture? Or is there another method, such as a small external lcd that I can easily plug into the 7d? Thanks, Rob |
The 7D has HDMI out that can be used with an external monitor.
It also has composite out and thats what I use when I put it on the Steadicam Pilot.
http://www.LandYachtMedia.com |
Thanks for the respons.
Is there something simple (and small) on the market that is easily plugged in the HDSLR, fixed on it and maybe even fed by it? If it is something big or complex, i go for a PAN GH1 or maybe even NIKON. |
Contributor
Most everyone uses a magnified viewer, like the Zacuto Z-finder, or one from Cavision or IDCPhotography. http://www.zacuto.com/z-finder-dslr-viewfinder or http://www.cavision.com/viewfinders/MHE52-5DBGSET.htm or http://www.idcphotography.com/kart/i...=129&parent=31
It is very difficult to shoot hand held or in bright sun without one of these. |
#5 |
But these are straigtforward. It is not possible to view into it from above with let's say an angle of 45 degrees. Does something like that exists? Anyway I have been shooting in bright daylight with the lcd on the hv20 for years! For me only the angle counts.
#6 | |
Marshall Electronics - V-LCD70P-HDMI http://www.lcdracks.com/monitors/V-LCD70P-HDMI_big.jpg But it's rather large and needs battery power. I also have the GH1, and I'll tell you right now, it's the best thing out there right now with a large sensor with articulating display (for the price). I couldn't decide between the 5D and GH1, so I got both, and the 7D on the way as well. Different tools for different needs.
www.holyzoo.com |
#7 |
i find the lcd to be ok in daylight. having to be on the same level all the time is annoying.
i was thinking (not very seriously) about a set of video glasses. If there was such a thing as an eyepiece for one eye it would be sweet! http://www.allvideoglasses.com/video-glasses-reviews |
#8 |
Hey Steev,
I was looking at that Marshall monitor, but I'm curious to see exactly what you see on it connected to the 7D. Could you post a photo of the live view in action on the Marshall monitor? |
#9 |
I am also curios about the Marshall on an articulating arm. Originally I was going to get the Ikan 5.6 but then I saw the Marshall with Peaking and other functions and thought this would be a better purchase. Wish I could get a smaller screen with HDMI and peaking.
#10 |
Rob,
One of the things I would consider is "rigging" a small mirror you could look down at. Maybe a piece of aluminum sheet bent at a 45 degree angle with a hole for 1/4x20 short bolt with knurled thumb knob to secure it to the bottom of the camera and a mirror glued to the "bent upwards" part. |
#11 |
Has somebody used these items:
With the Viewfinder LCD protector I will have a mirrored image. i suppose you can get used to that. With the LCD Angle-changing Viewfinder from LinkDelight I am not sure about the angle. Rob |
#12 | |
I'd like to hear if anyone has tried one. As for flipped image, that would drive me crazy. This all brings me to a few thoughts. If we're that serious about a video shoot, bringing along an external monitor should be standard. If just trying to run and gun it, I'd bring the GH1. I'll be testing mixing footage from the two cameras sometime this week. I'll also be testing the Marshall monitor with the 7D this week as well.
www.holyzoo.com |
#13 | |
#14 |
Back in the good old days when there was no LCDs the best approach was to keep both eyes open. The inside eye was looking through the viewfinder and the outside eye was kept open also. After matching the diopter the outside eye would match up with the angle of coverage of the eye looking through VF. This served as a way of getting an extended view of whats actually happening outside the frame. Useful for both creativity (in terms of planning ahead when shooting live) and safety.
A set of videoglasses as they are could work very well too though. Even if it was just a regular cheap set of SD glasses with a composite video-in. I would love to be able to try it out without outlaying the expense. The other offputting factor is how one would look going around with this kit. Candid shooting would be gone out the window anyway! |
#15 |
That link delight angle changer looks interesting Rob, cheap an cheerful.
i'd nearly always need the lcd pointing straight up as these days i usually shoot with the camera below my head level. |
