#16 |
Re: H.265 HEVC for Canon Cinema Cameras?
It's still Main profile, not High Throughput.
High Throughput is designed for acquisition and mastering, with intra only modes and much lower compression ratios, due to the ridiculously high maximum bitrate allowed, Think of it as the new MPEG-4 SSP (HDCAM SR) for 4K and 8K and beyond. There is going to be a "HDV" "subjective quality" uproar again with the introduction of HEVC recording in the professional realm. But I guess it all doesn't matter if it's convenient. |
#17 | |
I'd be curious to see what your HEVC-based project is where you had quality problems. I did a project back in February which was primarily HEVC from Filmic Pro and a GoPro Hero 6 (a promo that included rainforest hiking and rafting). I have zero of the issues you have brought up, and that's from consumer camera sources. |
#18 |
Well if you must know, my gauge of HEVC compression is from end delivery, and then translating that to how it might complicate things for acquisition.
#19 |
You have no experience with HEVC as an acquisition codec?
#20 |
I could have been watching Demo videos from consumer Demo TV sets with HEVC encoded content from LEGAL SOURCES at a Best Buy.
And just cause I don't produce that content now, doesn't invalidate all the points about how gradients are quantisized. Yet you go on the attack with wild assumptions of inexperience just cause you can. Quit it. |
#21 | ||
#22 |
Again, stupid projections and anti-FFmpeg bias with ProRes and their stupid implementation of ProRes. You decided to count FFmpeg as unprofessional and x265 as only used by pirates.
I was not watching the UHD Blu-rays. The demos were legally installed INTO THE TVs with pre-licensed content. |
#23 | |
Overall, the HEVC-based codec in the Canon XF705 will be perfectly fine to capture what the sensor is delivering. No one should be concerned, except for the obvious performance hit on older machines. |
#24 |
How can you actually prove that without asking the manufacturer directly? It could be a mezzanine format you export to the manufacturer is H.264 then they recompress it to fit on the flash memory inside the TVs in HEVC.
#25 | |
HEVC is a great new codec, and it's implementation in the XF705 is very interesting. I'd like to see Canon do that for the C300 Mark III in some respects, though the XF-AVC codec performs quite well on my current editing system. That would be my only concern about it. |
#26 |
Why? Space efficiency. The TVs only have a certain amount of flash memory for the Smart functions for it's operating system, and the demo videos.
You're speaking for yourself when you don't know a thing about FFmpeg and how widespread use it is for ACTUAL BROADCAST STUFF like converting stuff to DNxHD. Resolve uses FFmpeg on Windows. Is Resolve suddenly invalid for using FFmpeg? For ProRes, yes. (DEFINITELY YES on Windows) For everything else, no. |
#27 |
Which was still enough for the original 4K displays when they were all H.264 from years ago when they first launched.
#28 |
IN THE PAST.
Manufacturers have to take note of device resources and find better ways to allocate it. This has dragged on for way too long. I'm done with this. |
