Canon Notice Regarding C200 C200B Firmware Issue Interlaced Recording Issue at DVinfo.net
Old June 5th, 2018, 11:41 AM   #1
Canon released a notice today about a issue with Canon C200 C200B Cameras with Firmware Version 1.0.3.1.00 installed:
https://texasmediasystems.com/firmwa...and-eos-c200b/
Phenomena
Image quality degradation, such as color misalignment or edge distortion, may occur in the recorded footage when using the following combination of settings:
  • recording format XF-AVC
  • frame rate 59.94i / 50.00i
  • 1920×1080 resolution
Workaround
Users should use a configuration that does not include the settings listed above, although we acknowledge that this may not be possible for all users. Note: This Phenomenon only affects internally recorded footage. Output signals from the output terminals are not affected.
Affected Products
EOS C200 / C200B Digital Cinema Cameras equipped with Firmware Version 1.0.3.1.00 are affected.
Support
Firmware Version 1.0.3.1.00 has been removed from Canon’s Web site.
The new Firmware is scheduled to be released mid-June 2018.
Terry Nixon is offline   Reply With Quote
Old June 5th, 2018, 01:25 PM   #2
Re: Canon Notice Regarding C200 C200B Firmware Issue Interlaced Recording Issue
Thanks for the head's up! Very glad I have not had an interlaced-based project in a long time, though it's a shame Canon took so long to get this update (which has been very good so far), and neglected to Q&A the interlaced modes.
Old June 20th, 2018, 10:32 AM   #3
Canon released new C200 and C200B Firmware Version 1.0.4.1.00 to address the image quality issues mentioned in the post above.
https://texasmediasystems.com/canon-...date-released/
Firmware Version 1.0.4.1.00 incorporates the following fixes and enhancements
Fixes image quality degradation, such as color misalignment or edge distortion, may occur in the recorded footage when using the following combination of settings:
– recording format XF-AVC
– frame rate 59.94i / 50.00i
– 1920×1080 resolution
Optimizes the Black Gamma compensation when Normal 1 to Normal 4 is set for Gamma in the Custom Picture settings.
Optimizes color accuracy in areas of high brightness when Normal 1 to Normal 4 is set for Gamma in the Custom Picture settings.
Canon C200 Body 2215C002 $7499
Canon C200B Body 2215C002 $5999
CANON C200 CINEMA CAMERA & CN-E18-80MM COMPACT-SERVO LENS $11,599
Old June 20th, 2018, 03:53 PM   #4
Thanks for the notice on that, installing the update today!
Gary Huff is offline   Reply
