No AF on 18-80 Servo lenas and C100 Mk1 at DVinfo.net
Old May 11th, 2018, 07:18 PM   #1
My internet search brought me back to DVInfo for this question. I just rented a 18-80 Servo lens to use on my C100 Mk1 but the auto focus or auto iris does not work.
Is this true?
Thanks KPO
Kevin O'Connor is offline   Reply With Quote
Old May 11th, 2018, 08:09 PM   #2
Re: Help deciding between Canon CN 18-80 T4.4 vs 24-105
Kevin, seems to me that both should work -- I put a query into a contact at CUSA, however it's a Friday night, not sure when I'll get a reply.
Old May 11th, 2018, 08:16 PM   #3
Okay thanks for checking. Everything I've read so far states that Mk2 versions of camera bodies and up seem to work, I've read that earlier 5D and 7D bodies (that have Dual Pixel Focus) do not work with the AF on the 18-80 servo lens. So I'm guessing that my C100 Mk1, which I had dual pixel focus added, does not work.
Thanks KPO.
Old May 11th, 2018, 08:17 PM   #4
Re: Does the Canon CN 18-80 Servo AF work on C100Mk1?
Did you purchase a C100 Mark I that had DPAF on it, or did you have it installed on your C100 by Canon? Does it use DPAF with other lenses?
Old May 11th, 2018, 08:21 PM   #5
I purchased DPAF and had Canon install it. It works on all my Canon AF lenses.
Thanks KPO
Old May 11th, 2018, 08:22 PM   #6
Kevin, I heard back from my guy at CUSA (who may be reading this -- but corporate does not allow him to post). He says that as long as your C100 has the DPAF upgrade then that lens *should* give you AE & AF.
Gotta be some wrong setting somewhere. Does the lens have a hand grip, and is it properly plugged in? Don't know if the grip makes a difference though.
Old May 11th, 2018, 08:25 PM   #7
It does not have the add on hand grip. Rental store said they have an early model that did not come with he hand grip.
Now I'm wondering if the lens is working right? I knew I should have checked it out a tthe store and of course I skipped on the insurance.
Old May 11th, 2018, 08:36 PM   #8
Kevin, the camera must be running the latest firmware.
It needs to be version 2.0.9.1.00
If you don't have it, you can download it at https://www.usa.canon.com/internet/p...loads-firmware
Old May 11th, 2018, 08:43 PM   #9
Re: No AF on 18-80 Servo lenas and C100 Mk1
Posts moved from another thread to its own topic.
Old May 11th, 2018, 08:59 PM   #10
I have not updated the firm ware sense the DPAF was installed. It at 2.0.3.1.00
I'll try the like to update.
Thanks KPO
Old May 11th, 2018, 09:16 PM   #11
i have the down load but cant find the pdf directions. Just dragging the file to a SD card and loading in the camera is not working,
How do you get the camera to update the firm ware?
Old May 11th, 2018, 09:29 PM   #12
The download is an executable that you have to open on a computer first. Instructions for the exact procedure about how to do the update is part of that package. Open the file first (.zip for Windows; .dmg for Mac) and go from there.
Old May 11th, 2018, 09:50 PM   #13
NOTES:
Firmware Version 2.0.9.1.00 incorporates the following correction.
1. When CN-E70-200mm T4.4 L IS KAS S is attached the following features are enabled:
- Autofocus using the Dual Pixel CMOS AF function
- The joystick on the camera's grip unit can be set to operate the zoom.
- Manual control of the iris with Camera's Control dial.
- Control of focus, zoom and iris using the separately-sold Remote Controller RC-V100.
- Automatic aperture and push auto iris functions.
- Start/stop recording on the separately-sold lens grip ZSG-C10.
- Retrieval of Lens metadata, such as the model name and the focal distance will display on the camera.
2. When the camera is turned off the IS mechanical lock will be active regardless of the position of the switch.
3. Adds peripheral illumination correction for the following lenses:
COMPACT-SERVO Lens
- CN-E70-200mm T4.4 L IS KAS S
EF Lens
- EF 70-300mm f/4-5.6 IS II USM
- EF 16-35mm f/2.8L III USM
- EF-S 18-55mm f/4-5.6 IS STM
- EF-S 35mm f/2.8 Macro IS STM
- EF 85mm f/1.4L IS USM
Caution:
Firmware Version 2.0.9.1.00 is only for EOS C100 cameras which have Firmware Version 2.0.3.1.00 - 2.0.8.1.00 with the Dual Pixel CMOS AF Feature Upgrade applied. If your camera's firmware is already version 2.0.9.1.00, it is not necessary to update the firmware. Once the camera is updated to the latest firmware version, it cannot be restored to a previous version.
Preparations for a firmware update:
After the Firmware update has been performed, the camera's menu settings and Custom Picture settings will be reset. It is recommended that users save their menu and Custom Picture settings as settings data to an SD card, separate from the one that will be used to carry out the update, before starting update operations. This saved data can be loaded into the camera and the settings can be changed after the update has been completed. For further information on this, please refer to the section in the camera's user manual titled Saving and Loading Camera Settings.
The downloaded firmware folder contains the firmware (File Name: VKG9.FIM, File Size: 35,067,076 bytes) and a procedure manual for updating the firmware (a PDF file in five languages: Japanese, English, French, Spanish and Simplified Chinese). Please check the firmware update procedure manual carefully before starting update operations.
The following things are required to perform this firmware update:
1. A Cinema EOS C100 (with the Dual Pixel CMOS AF Feature Upgrade applied) camera body
2. A computer (OS: Mac OS 10.7 - 10.13)
3. A 64 MB or higher-capacity SD / SDHC / SDXC memory card (both commercially available)
4. A memory card reader (commercially available) or an SD memory card slot on the computer
5. A fully charged battery pack for the camera
6. Compact power adapter bundled with the camera
7. The firmware (the downloaded file)
History
Changes in Firmware Version 2.0.8.1.00:
1. The following features are enabled when these lenses are attached: CN7x17 KAS S/E1*, CN-E18-80mm T4.4 L IS KAS S or CN20x50 IAS H/E1*.
- Saving and displaying Metadata, such as the model name and the focal distance of the lens attached.
- Support for peripheral illumination Correction.
- Manual Iris control via the camera's control dial on the grip.
- Zoom operation via the joystick on the camera's grip.
- Support for Dual Pixel CMOS AF function. (Not applicable to the CN20x50 IAS H/E1 lens)
- Operation of REC start/stop via the lens's grip unit.
*The lens firmware also needs to be updated. If you have CN7x17 KAS S/E1 or CN20x50 IAS H/E1, please contact to Canon Support Center.
2. Adds Peripheral Illumination Correction for the following lenses:
- EF 35mm f/1.4L II USM
- EF 50mm f/1.8 STM
- EF-S 18-135mm f/3.5-5.6 IS USM
- EF 24-105mm f/4L IS II US
Changes in Firmware Version 2.0.7.1.00:
1. Corrects the tone parameters when [Light Metering] is set to [Backlight] in [Camera Setup] and when specific custom picture settings* are selected.
* If any of the settings below is selected for custom picture settings:
- [Preset Custom Picture Files] is set to [C8:Wide DR] or [C9:CINEMA].
- [Color Matrix] is set to [Wide DR] or [Canon Log].
Changes in Firmware Version 2.0.6.1.00:
1. Fixes a phenomenon in which, when specific lenses* are attached to EOS C100 (Dual Pixel CMOS AF) cameras running Firmware Version 2.0.5.1.00, the image stabilization mechanism does not operate even when the lens' IS switch is in the ON position.
(*EF 24-70mm f/4L IS USM / EF-S 15-85mm f/3.5-5.6 IS USM)
Changes in Firmware Version 2.0.5.1.00:
1. Enables peripheral illumination correction for the following lenses:
- EF lenses:
EF 16-35mm f/4L IS USM
EF-S 10-18mm f/4-5.6 IS STM
EF 400mm f/4L DO IS USM
EF 11-24mm f/4L USM
EF 24-105mm f/3.5-5.6 IS STM
EF 100-400mm f/4.5-5.6LII IS USM
EF-S 24mm f/2.8 STM
- CINE-SERVO lens:
CN7x17 KAS S/E1
2. When one of the following EF lenses is attached and power is turned off, the lens automatically retracts to its minimum length:
EF 40mm f/2.8 STM
EF-S 24mm f/2.8 STM
EF 50mm f/1.8 STM
Changes in Firmware Version 2.0.4.1.00:
1. Compatibility with the Canon RC-V100 Remote Controller has been added. This enables setting and adjustment* of items such as exposure and white balance of footage while away from the camera.
*It is necessary to select the [RC-V100] from the camera's [REMOTE Term.] menu.
2. Peripheral illumination correction data has been added for the [CN-E35mm T1.5 L F] EF Cinema lens and the [EF-S 55-250mm f/4-5.6 IS STM] EF lens.
3. Fixes a phenomenon in which the EF Cinema lens' F number was incorrectly displayed.
Changes in Firmware Version 2.0.3.1.00:
1. Dual Pixel CMOS AF technology Feature Upgrade applied.
Old May 11th, 2018, 10:03 PM   #14
Yeah, it worked. Thanks for the help and the download info. I was able to up date my C100 firm ware to the latest and the 18-80mm Servo lens is working great.
Thanks again because this saved me from running back to the rental store before my job tomorrow. Now I need to apologize to the rental store for the phone message I left, oops.
Take care, KPO
Old May 12th, 2018, 11:14 AM   #15
This was all due to a certain Canon pro rep who answered my text pretty late in the evening and took time out to help on a Friday night. I'll see him next month hopefully, and will thank him in person for you. Glad to hear all is working well.
Chris Hurd is offline   Reply
