C200 - Second Test - Skin Tones at DVinfo.net
Old April 8th, 2018, 11:01 AM   #1
Hello there,
I've made a new test in Rawlight, more oriented to evaluate the skin tones, let me know if the color correction it's good enough :
Cheers! :-)
Danilo Del Tufo is offline   Reply With Quote
Old April 9th, 2018, 09:25 AM   #2
Re: C200 - Second Test - Skin Tones
Danilo, it looks a little cool to me. Maybe try to get that nice warm glow that Canon is famous for. Also, just for my own knowledge what lens were you using? Bob
Old April 11th, 2018, 02:14 AM   #3
Thanks, Bob. In this test I was using EF 50MM f/1.4 USM STANDARD, at maximum aperture, ISO 800 - ND 6 (the sunlight was very strong). Maybe the maximum aperture has taken too much light causing a little overexposing and cool colors. Till now I still can't have the same results of others C200's users, I'm coming from an HPX170 and this C200 is more difficult to use, you need to be skilled enough.
Here there are two PNG images taken from Premiere, please try to color correct them and give more advise. Constructive criticism is welcome. Thanks again! :-)
First image, no color correction: https://ibb.co/deGYpx (I've reduced the image in FULL HD in Photoshop)
Second image, no color correction:https://ibb.co/eKkb9x (I've reduced the image in FULL HD in Photoshop)
Old April 13th, 2018, 07:52 AM   #4
From a photography reference and Sunny 16... to be a f/1.4 at ISO 800 (and assuming your frame rate is around 1/60), you need to account for 11 stops.
Ricky Sharp is offline   Reply With Quote
Old April 13th, 2018, 11:55 AM   #5
It's 1/50 frame rate. So what I gonna do about it? What I must change in values?
Old April 13th, 2018, 12:12 PM   #6
TEST:
Old April 19th, 2018, 12:27 PM   #7
New LUT by a friend of mine. Better skin tones from my previous attempt - Canon C200 - codec Rawlight - lens canon 50mm 1.4 - ISO 800 - ND 6
C200 - Second Test - Skin Tones-nuova-lut-copia-copia.jpg   C200 - Second Test - Skin Tones-noemie-gabriele.jpg
