C300 mkII Frame Rates? at DVinfo.net
Old July 20th, 2016, 04:51 PM   #1
I've looked at the specs over and over and it's still a mess. Looking at the B&H specs page is confusing as there's a thousand rates, bitrates, sizes. Does anyone know of a good resource for C300 mkII frames rates that easy to read? Some type of spreadsheet would be great.
www.scott-gold.com
Scott Gold is offline   Reply With Quote
Old July 20th, 2016, 06:27 PM   #2
Re: C300 mkII Frame Rates?
This is the list from B&H:
Frame Rate 59.94 Hz Mode
59.94i/p, 29.97p, 23.98p
50 Hz Mode
50i/p, 25p
24 Hz Mode
24p
Last edited by Pete Bauer; July 20th, 2016 at 06:48 PM. Reason: removed inflammatory statement
Old July 20th, 2016, 09:10 PM   #3
Perhaps I should have been more detailed.
I'm looking for a spreadsheet/matrix that shows all the different combinations of frame rates, resolutions and bit rates. Found what I needed on page 63 of the online user manual if anyone else ever needs it.
www.scott-gold.com
Last edited by Pete Bauer; July 21st, 2016 at 07:27 AM. Reason: Removed reference to inflammatory statement
Old July 20th, 2016, 09:12 PM   #4
Only 1080/2K can do 59.94i/p and 4K does all the rest.
Old July 22nd, 2016, 03:21 AM   #5
I wonder if there's any chance in the big firmware update that's due in a week's time they'll enable 4K 50/60P - apparently the camera's capable of it, they have just chosen not to enable it.
Mathew Williams is offline   Reply With Quote
Old July 29th, 2016, 09:04 AM   #6
Clearly the answer is "no". Canon is not in the habit of adding surprise features. They clearly announce their intentions. It was not intentionally crippled.
Old August 1st, 2016, 05:01 PM   #7
So for my next question...what about the crop at these frame rates?
Am I right to say that you can shoot any resolution up to a frame rate of 60p on the full sensor?
Once you go over 60p you have to crop? Is that right?
www.scott-gold.com
Old August 1st, 2016, 05:27 PM   #8
I've searched and only found the attached chart in the manual. Still, I don't see anything clearly defining the crop factors and frame rates. If a C300mkII owner could confirm that would be awesome. Thanks!
www.scott-gold.com
Last edited by Pete Bauer; August 2nd, 2016 at 07:41 PM. Reason: Pruned responses to OT post
Old August 2nd, 2016, 09:07 AM   #9
Scott, a bit off topic but just checked out some of your work and that's an impressive portfolio you have got, I particularly liked January in Japan, makes me want to jump on a plane and fly there :)
Old August 2nd, 2016, 10:41 AM   #10
Noa, thanks for the nice comment man, I appreciate it. :)
www.scott-gold.com
Last edited by Pete Bauer; August 2nd, 2016 at 07:42 PM. Reason: Pruned response to deleted OT posts
