Final Cut Pro now ready for C300 mkII at DVinfo.net
Old February 4th, 2016, 08:52 PM   #1
Apple updates Final Cut Pro X, Compressor and Motion with new features
Paul Chiappini is offline   Reply With Quote
Old February 4th, 2016, 09:55 PM   #2
Re: Final Cut Pro now ready for C300 mkII
This is great news. Have been back heavily in Premiere at the moment because I didn't want to get stuck using FCPX for a project and discover it didn't like the C300 footage. Glad that's been..
...resolved.
Old February 5th, 2016, 01:48 AM   #3
yeah - really timely update and great news.
You need to install the Canon XF Utility 2.1 for XF-AVC available at Canon’s website in the Driver & Downloads > Software section.
This might just be the final feather to tip the balance in my quite painful decision making process between the C300 MK2 and Sony FS7 although having used the C300 since it was launched I should really just go ahead and buy the new camera.
Mark Dobson is offline   Reply With Quote
Old February 5th, 2016, 05:49 AM   #4
Do you actually need this? Seems like the support is built-in now.
Old February 5th, 2016, 11:15 AM   #5
Yes apparently you do - I upgraded my XF Utility for FCPX to version 2.1.
The other side of the equation is within todays minor FCPX upgrade. E
Either way it all works now. I tested some 4K files I shot with the Canon XC10 and it was a seamless experience.
Old February 5th, 2016, 11:53 PM   #6
I am a bit confused. I used to edit the C300 Mark II files in the prior version as well. And am yet to upgrade to the new version. I am now currently editing a doc so not upgrading to the latest. Will wait to hear if this upgrade is stable or not
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old February 6th, 2016, 12:30 AM   #7
Sabyasachi, the FCPX 10.2.3 update is a very minor one and I have had no issues with it at all.
I couldn't import XF-AVC files before this although I had heard that the last update enable import of the XC10 files which are 422 8bit I think.
Old February 6th, 2016, 08:47 AM   #8
You need to install the Canon XF Utility 2.1 for XF-AVC.
I looked into this because I was confused as I had well already installed XF Utility 2.1 from back in September and I didn't see why that would suddenly change anything with a new FCPX update.
There is a new version of XF Utility, version 3.1 is the one you want.
Old February 6th, 2016, 11:29 PM   #9
Thanks for that Gary.
Yes there is the new Canon XF Plugin for Final Cut Pro x 3.1 which I had not seen
I had upgraded the Canon XF Utility 2.1 for XF-AVC (Mac OS X) which has been out since Oct 2015
Separate bits of software.
