Thread Tools
Search this Thread
#16 |
Re: C100 Missing Frames Between Split Files
Or have someone copy the CD for you - I'd be game if I can find mine.
#17 |
#18 |
I have the Mk1. It came with the CD for Version 2.1
I found the CD. I copied the files to Dropbox as follows. This is for Windows. I'll upload a different folder for Mac in a little while https://www.dropbox.com/sh/9cgvyo58s...PJ-bq8N5a?dl=0 |
#19 | |
#20 |
My wife was using the Mac most of the evening. I might be able to make an ISO image of the CD on the PC if that would be useful
Edit: OK I figured out how to copy the CD to an ISO file so it should have everything you need for Mac and/or Windows. The file should be an exact image of the CD. https://www.dropbox.com/s/jthyd0qgdg...tUtil.iso?dl=0 |
#21 |
Thanks Jim! I downloaded to my dropbox. I'll check everything later this evening.
#22 |
Great Troy
I hope it works for you. I haven't installed myself yet it because (as I said above) I use the Ninja when on a tripod. |
#23 |
Windows Premiere Pro user here. I work with both Mk1's and Mk2's. I never had an issue syncing long takes with the MTS files after using the data import utility to copy the files. I hated having to copy the whole card over, so I was very pleased with how well the data import utility worked.
Now with the MK2, I'm getting sync problems with long MP4's that have been merged with the newest version of the data import utility. Some long files go out of sync with other files, and I sometimes even have glitches where near the end of a long take MP4, the sound will totally go out of sync with the picture in the same file in Premiere. I haven't done a thorough testing to see what the problem is. |
#24 |
