Canon C100 with 24-70 Lens at DVinfo.net
Old December 18th, 2014, 06:21 AM   #1
I'm thinking about buying this lens, but the lack of image stabilization makes me think twice. How forgiving is this lens when it comes to movement? I typically shoot on a monopod.
Kevin Lewis is offline   Reply With Quote
Old December 18th, 2014, 06:23 AM   #2
Re: Canon C100 with 24-70 Lens
As long as you use a monopod you should get away with fairly stable footage but shooting handheld will introduce small jitters in your image.
Old December 18th, 2014, 11:40 AM   #3
With the crop factor of the C100, consider the EF-S 17-55 f/2.8 IS instead. Excellent optically, constant f/2.8, and image stabilized.
If you really want the 24-70 range, considering crop factor, the EF-24-70 f/4 IS is image stabilized, and optically really good (better than the EF 24-105 f/4 IS.
I have owned all three.
Richard D. George is offline   Reply With Quote
Old December 18th, 2014, 08:33 PM   #4
I have a friend who has the 24-70 f2.8 that he uses on his Red Epic, and he has had issues with soft images at some focal lengths above 50mm (which seems weird). I use the 17-55 now as my main lens on the C100... I really appreciate the IS, and the f2.8. As Richard points out, the crop factor makes it very close to a full frame 24-70, and I would definitely recommend trying it.
C100, 5DMk2, FCPX
Old December 20th, 2014, 04:53 AM   #5
I shoot with C300 and use the 24-70 f2.8 L when I use tripod or other forms of support. However, I had been to my village for a family festival. It was the 85th annual Laxmi Puja (Laxmi is the Godessess of wealth). The light levels were very very low. I was forced to use this lens handheld (without any rigs just holding the camera infront of me like a DSLR for major portions). I was also not aware about the sequence of some of the rituals so I had to react like typical run-n-gun. So don't blame me if this doesn't meet your aesthetic sensibilities. :)
To summarise, I feel you can use the 24-70 handheld with your C100 with a monopod. Shot in c-log.
Some of the very dark shots were cleaned up with neat video.
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old January 7th, 2015, 06:09 PM   #6
I would say it's do-able, especially with the smoothing features in most NLE software these days (depending on how big you're planning on displaying this image). But, as others have mentioned, the 17-55 2.8 IS is quite nice, i use it myself. The 24-105 IS f/4 is also a decent choice. You might also consider the Tamron 24-70 f/2.8 DI VC USD. It's the best combo, Image stabilized, Full Frame coverage, so compatible with 5D etc, and bright 2.8. Hope that helps.
Eric Petrie
provideoandtape.com
Lease The Canon C100 starting at $129 a month
Lease the Sony FS7 starting at $248 a month
Eric C. Petrie is offline   Reply With Quote
Old February 20th, 2015, 07:25 AM   #7
I have the Tamron 24-70 2.8 VC and it's awesome. Easily as sharp as the Canon and it has stabilization.
Bill
Cinema Couture
www.cinemacouture.com
Bill Grant is offline   Reply With Quote
Old February 20th, 2015, 07:43 AM   #8
Another vote for the EF-S 17-55mm f/2.8 IS instead of the EF 24-70mm f/2.8 L.
The 17-55 will never be branded as an L series lens, but for all practical purposes, with regard to optical performance it is indeed L series quality.
All you're giving up is full-frame still camera capability, and some weather sealing. But you're gaining image stabilization and it's less than half the price of the EF 24-70. The constant f/2.8 max. aperture is the same between both lenses. And the wider field of view is much more useful in my opinion.
I would choose the EF-S 17-55mm f/2.8 IS over the EF 24-105mm f/4 L IS as well, because it is faster (and still less expensive).
However there is also EF 24–105mm f/3.5–5.6 IS STM which will allow Face Detect AF because it is STM whereas the EF-S 17-55 is not STM. Also this lens is considerably less expensive than the EF-S 17-55.
These plus the Tamron previously mentioned and others... we're embarrassingly rich in choices, I think.
Chris Hurd is offline   Reply
