Importing clips from the C100 at DVinfo.net
Old October 18th, 2014, 09:23 PM   #1
I just got the C100 and a Ninja Blade, I'm waiting for the recommended Hard drive to arrive in the mail so I can begin to use the Ninja. In the meantime I'm wondering about the correct way to import clips into FCPX.
I've recently heard of the problem of FCPX has with AVCHD codec. I imported the clips via the USB cable using Data import utility then transcoded them using 5DtoRGB.
Is this a good way to do it?
Michael Thames is offline   Reply With Quote
Old October 18th, 2014, 09:52 PM   #2
Re: Importing clips from the C100
Here's some info that may be helpful!
Troy Moss is offline   Reply With Quote
Old October 19th, 2014, 12:23 AM   #3
Thanks Troy, I thought there was an issue of having to manually adjust the clip settings to progressive because FCPX see's the C100 as interlaced? I'm wondering if 5DtoRGB does this automatically?
Old October 19th, 2014, 05:58 AM   #4
I've never had the problem you are describing. Have been using C100 for almost 2 years now.
Kathy Smith is offline   Reply With Quote
Old October 19th, 2014, 02:14 PM   #5
It was Dave Partington who said this just recently in this thread.
http://www.dvinfo.net/forum/panasoni...tting-gh4.html
The clips look good to me after running them through 5DtoRGB...... but the thought occurred maybe they will look better doing what Dave said...... I don't know...... Dave are you out there?
Old October 19th, 2014, 05:00 PM   #6
I just read his comment on the other thread and have no idea what he is talking about. Maybe he will explain if he sees this thread.
Old October 19th, 2014, 08:57 PM   #7
Kathy, if you don't mind me asking what is your workflow?
Old October 20th, 2014, 12:27 AM   #8
Kathy, I guess you're using 24p pretty much exclusively?
A while back, I settled with the sort of ham fisted but reliable FCPX 'select all clips and switch to Progressive' for all my 25psf stuff:
Canon C100 PsF – the fix | Travelling Matt
24p seems just fine, 24psf isn't.
If I have the time/budget/inclination, I go the 5DtoRGB route - but most of the time, everything just gets sucked straight into FCPX and once it's all in but before I start putting things into a project/timeline, I switch to Progressive.
EX1 x2, C100 --> FCPX & PPro6
Old October 20th, 2014, 05:02 AM   #9
Hi Matt, yes I am using 24p exclusively. I don't even know what 24psf is for, hahaha.
Old October 20th, 2014, 09:31 AM   #10
Matt, thanks for the info. It takes some of the mystery out of what Dave was saying.
Yea, I tried to google what on earth you would use psf for and couldn't find an answer, I'm sure there is a reason otherwise Canon wouldn't have put it in there. However, for me no reason to shoot in anything other than 24p....... so it's a non-issue I guess.
Old October 20th, 2014, 09:50 AM   #11
Here you"ll find some more info regarding this: http://www.dvinfo.net/forum/canon-ci...uggestion.html
Old October 20th, 2014, 10:53 AM   #12
I always import from the card and not via USB.
If you import from the AVCHD structure then FCPX (and most other NLEs) see the footage as interlaced not progressive, so you ned to click on the clip in the event browser then in the inspector (cmd+4 to open) in the info tab change it to progressive.
Several apps, including ClipWrap and maybe 5DtoRGB do this change for you when re-wrapping, but it's a stage I usually don't bother with because it's not required since I can do everything inside FCPX.
If the workflow you are using works for you and when you check the info panel in FCPX it says progressive then you are good to go.
If however you ever seen any interlace type artefacts in the FCP viewer then check the progressive settings in the info panel.
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old October 20th, 2014, 03:37 PM   #13
Dave, do you shoot 50i or pf25?
Just interested. Ta.
Avey
theactionhouse.com
Wayne Avanson is offline   Reply With Quote
Old October 20th, 2014, 03:48 PM   #14
I shoot PF25.
Old October 20th, 2014, 07:43 PM   #15
Hi Dave, I've always used the USB cable on my 5D3 to import the footage. Do you think there is a difference in the quality of the image doing it this way rather than a card reader?
Here is something a shot yesterday in my back yard. How does this footage look to the trained eye? I didn't see any jaggies and I've noticed some very bad jaggies on some other C100 footage that is considered very good on Vimeo.
I used data Import, then ran the clips through 5DtoRGB.
