#16 | |
Re: Importing clips from the C100
#17 |
Re: Importing clips from the C100 mk2
I know it's an older thread but I recently got a Canon C100 MKii and I decided to record on MP4 instead of AVCHD...simpler to use with FCP 7 (I know I'm a relic!). Anyway, my workflow is MP4 then into my mac via iphoto (as I do with my Canon 70D), then convert the files to Apple Pro Res LT via mpeg streamclip and is looks to work ok...or should I be using the Canon import software? does the footage get imported deinterlaced as it should or not? Just want to make sure I do the importing properly.
thanks Erick
http://www.fandangovideo.com Canon C100 mark 2, Canon XF300 & XF100, Canon 90D, Sony a6400,Ronin S etc etc |
#18 |
I'm now using some software called EditReady prior to import in to any NLE. It can either re-wrap or transcode, but the important thing is that it created uncompressed audio which has the advantage of:
• Premiere Pro doesn't need to conform audio • FCPX doesn't need to copy the files in to it's library, it can use them from wherever you choose to put them • You can transcode for FCP7 - and it's faster at doing it that compressor, MPEGStreamclip and all the others I tried. I was so impressed with it I wrote a quick review here: Review: EditReady - DavidPartington.com
Qualified UAV Pilot with CAA PFAW Aerial Photo / Aerial Video | Corporate Video Production |
#19 | |
Deinterlacing your C100 footage will kill half the resolution. |
#20 |
hi Gary. thanks for the reply!
I read somewhere about some people choosing deinterlacing with the C100 footage and thus losing half the resolution so when open streamclip to transcode the mp4 files ( I have been shooting 1080 60p to have the option to do some slow mo if required but the timelime has been set at 30p for normal playback) I DON'T choose deinterlace when transcoding to apple pro res LT. Is this correct? I don't want to lose the quality! I love the camera so far! i will keep my 70D as a B camera with this one. thanks for the help! |erick
#21 |
