#16 | |
Re: Canon C100 Goodness
#17 |
The lens I used with the glide cam is 16-35 2.8L
the go pro was used in all the aerial drone shots |
#18 |
Thanks. How long have you been using the glidecam? I have exactly the same one, same camera, same lens and can't even balance it properly. Nevemind using it. I wonder if you could tell me how many weights you use with the C100 and 16-35 lens. Any other tips on using the Glidecam with C100?
Thanks. |
#19 | |
I suggest first using a quick release plate, and placing levels on the glide cam to ensure horizontal and vertical balance. I use 4 weight plates on each end because i often run same setup with a ninja 2 attached. Legs fully extended, I aim for a 3 second drop time. |
#20 | |
By legs do you mean the wings that you put the weights on? Or do you mean the vertical column? |
#21 | |
and by legs i mean the wings that you put weight on. |
#22 | |
#23 |
#24 |
#25 |
I've made another graffiti video using the same equipment and some interesting camera movement, this one is shorter and more concise it's worth a look.
Cheers |
