Transcoding for AE and FCPX- What's best? at DVinfo.net
Old May 26th, 2014, 08:43 AM   #1
So far I've been letting FCPX transcode but I've been finding the old PsF to progressive buggy. I have to keep checking and changing to progressive.
I have a project that I'm going to do a lot of work in AE before finishing in FCPX. I'd like to work in ProRes so what would be the best program to transcode the footage and have progressive set so I don't have to deal with the PsF problems (specially as I'll be using 2 programs to edit)?
Andrew Maclaurin is offline   Reply With Quote
Old May 26th, 2014, 10:21 AM   #2
Re: Transcoding for AE and FCPX- What's best?
I use Clipwrap to transcode the files to ProRes422 for FCPX Works fine for me.
Avey
theactionhouse.com
Wayne Avanson is offline   Reply With Quote
Old May 26th, 2014, 10:25 AM   #3
Hi wayne, can you set the footage to be proper progressive with clip wrap?
Old May 26th, 2014, 02:06 PM   #4
Hi Andrew
Yes Clipwrap will help FCPx to correctly interpret the footage as progressive. So no more having the change the setting in FCPx.
Drew Curran is offline   Reply With Quote
Old May 27th, 2014, 01:07 AM   #5
Thanks, Drew, would that be the same for After Effects?
Old May 27th, 2014, 06:41 AM   #6
PMJI with my usual clarion call for 5DtoRGB, but it does help both the Progressive Fields thing and also does a useful amount of smoothing on the Chroma channel - making it somewhere between AVCHD and ProRes (not really, but it actually does help strong reds).
5DtoRGB by Rarevision
There's a free version and a very affordable batch version. Mac and Windows.
EX1 x2, C100 --> FCPX & PPro6
Old June 4th, 2014, 03:24 AM   #7
I don't use AE for much other than some camera tracking and titles etc so I can't say if ClipWrap will help for direct import. I generally export a ProRes clip of a region on the timeline in FCPx to import in to AE.
Old June 4th, 2014, 08:10 AM   #8
AE can handle C300 footage natively as far as I know. Unfortunately the drive with my last C300 shot talking heads isnt here or I would check real quick.
Automotive Multimedia
Justin Molush is offline   Reply With Quote
Old June 13th, 2014, 10:02 AM   #9
I found getting something like a Ninja 2 took care of all my problems and really speeds up post production. A recorder like that takes you from 8bit 4-2-0 to ProRes 10bit 4-2-2 220 Mbps which really helps in AE and green screen. When finished, ust pull out the drive and load the ProRes files into your project. They now run about $800 with drive and also make a decent monitor. The negative is they are bulky.
Producer/Writer/Director
www.HouseonRodeoGulch.com
Bill Scherer is offline   Reply
