Help - 1DC keeps stopping at DVinfo.net
Old March 15th, 2014, 06:20 PM   #1
On my last shoot, my 1DC gave me an error message a few seconds after hitting record. Something like "Recording has automatically stopped." I had plenty of space on the CF card and I had freshly formatted it in the camera. Since then, it's now happened several times.
Anyone have this problem? Any solutions/suggestions?
Thanks.
Steve Kimmel is offline   Reply With Quote
Old March 15th, 2014, 06:47 PM   #2
Re: Help - 1DC keeps stopping
Hi Steve, can you please identify your CF card as precisely as possible (make, model specs, etc.) and also what your video recording settings are (frame rate, size, etc.) -- thanks in advance,
Old March 15th, 2014, 08:10 PM   #3
Sure. It's a SanDisk Extreme Pro 256GB 160MB/s, 4K, 24fps, C-Log.
Old March 17th, 2014, 11:09 AM   #4
You should probably try a different card and see if it works better. A bit of problem solving seems in order. Is it the card? The camera? Frame size? Even if a card is approved doesn't mean yours is functioning properly. Does the same issue happen when recording to 1920x1080. good luck
Old March 17th, 2014, 12:34 PM   #5
I agree. It seems to be more than 1 card but I haven't yet had a chance to systematically test. That's my next step. Thanks.
Old February 12th, 2017, 07:55 PM   #6
This is an old post and has probably since been resolved but, this issue can be easily solved by using a card with the appropriate read and write speed.
Maurice Covington is offline   Reply
