new firmware c100 at DVinfo.net
Old November 13th, 2013, 02:47 AM   #1
new firmware c100
new frimware c100 is hiere
Canon U.S.A. : Professional Imaging Products : EOS C100
thanks canon
Docea Marius is offline   Reply With Quote
Old November 13th, 2013, 04:19 AM   #2
re: new firmware c100
Remember to back-up your settings to SD card before you install new firmware it wipes all your settings to factory default. PS: To get the Magnify to move switch your lens to Manual Focus.
Old November 13th, 2013, 04:26 AM   #3
How do you backup the settings?
Owen Kilgour is offline   Reply With Quote
Old November 13th, 2013, 04:40 AM   #4
Other Functions > Transfer Menu/CP
Old November 13th, 2013, 05:45 AM   #5
I have a problem installing the new Frimware but I managed to change the magnification point central..
I tried to move it with joistik site does not work .. can be activated in the menu?..anyone tried if it works?
Old November 13th, 2013, 05:53 AM   #6
For the benefit of lurkers, switch your lens from AF to MF to get MAGN. moving with the joystick.
EX1 x2, C100 --> FCPX & PPro6
Old November 13th, 2013, 12:00 PM   #7
Re: new firmware c100
Thanks Matt and Nicholas! Couldn't figure out how to switch the focus square. SOOO nice to have this feature finally, off to use it!
Jef Gibbons is offline   Reply With Quote
Old November 13th, 2013, 03:17 PM   #8
Just spent the morning shooting with it, it works really well. A little bit strange getting used to the fact that if you push it out of the boundary it jumps to the bottom or the side (so if you push it up and up it jumps to the bottom). Also a little more precision on it would be sweet, but sometimes I felt the 5D's would take too many presses to move that little square around.
