Do you have to use a LUT with C300 footage?
If I shot a bunch of footage in Canon Log, does it mean I must use a LUT when color correcting? Correct me if I'm wrong, but I thought LUT's were just guides that get you 90% there, you can color correct without them if you like.
www.scott-gold.com |
Re: Do you have to use a LUT with C300 footage?
No LUT required, and yes it gives you an idea of how things are going to look.
I can only refer to my own experience and I've been filming with Canon Log for the last 18 months and have never used a LUT although in many respects the View Assist on the C300 screen must in some way incorporate a LUT. If you shoot and edit your own material it's a great way of working, providing a lot of latitude in post production and I've got pretty quick at correcting or optimising the files. I use FCPX and end up boosting saturation, sharpness and correcting the levels using the scopes. The results are very rewarding even though it does take a lot longer than editing with the standard settings that come with the camera. I normally end up doing a lot of secondary corrections. However within an edit many shots will be very similar and it's possible to save a lot of time with paste attributes and doing some minor tweaks. |
Cool, thanks for the reply.
You add sharpening in post? I thought that was something only done on 5Dmk3 footage.
It's certainly something I like to do.
This is what Canon says about Canon Log: "Canon Log is a log gamma setting that retains maximum image information for post-production. It has high dynamic range and records the image with a flat image quality with subdued contrast and sharpness. This is ideal for color correction" Here is a link to the Canon Web page I lifted this from: Canon DLC: Cinema EOS Frequently Asked Questions Canon DLC: Cinema EOS Frequently Asked Questions |
#5 |
You may like to check out 'Film Convert':
FilmConvert - Film Stock and Grain Emulation Software It has a (downloaded separately) C-Log setting for both C300 and C100. It's not a 'film look' plug in applied in secondary grading - it's the closest one would get to a 'LUT' for C-Log. It's not for every shoot, it's not for every shot, but it does some wonderful gamma and colour manipulation that C-Log seems to like. Corporate shooters may want to step away, but I love it. Edit: BTW, sharpening in post is very, very nice. It can be disconcerting to see unsharpened (minimum detail) rushes, but a little dab of sharpening in post is like the first time you try on your new glasses - oh, so THAT's what it looks like! Sharpening in post is better than in-camera as you can vary it shot by shot, and because it's not done in a fraction of a second, the NLE tends to do a neater, more pleasing job.
Director/Editor - MDMA Ltd: Write, Shoot, Edit, Publish - mattdavis.pro EX1 x2, C100 --> FCPX & PPro6 |
#6 |
I exclusively use c-log with my C300 and don't use any LUTs. It is important to get the shooting parameters right and the post processing doesn't take much time.
#7 |
Hi guys, im new to the forum. I have been struggling with exporting my short film that was shot on a c300.
I'm getting compression artefacts even on mp4 @ 24 mbps. pixel blocks and round circular bands in darker areas. are there any ways to export the film that will reduce such effects. thanks. |
