This lens won't shoot 4K, will it? at DVinfo.net
Old September 13th, 2013, 10:06 AM   #1
Am I right in thinking this lens could not be used with an adaptor to shoot with the 1DC in 4K mode because the glass only covers 16mm?
http://www.ebay.com/itm/VINTAGE-16MM...item2c67745f0f
Input would be appreciated :)
Pierre Aguillard is offline   Reply With Quote
Old September 13th, 2013, 10:21 AM   #2
Re: This lens won't shoot 4K, will it?
I would pass on that for shooting 4K.
The front element looks like it has seen better days as well.
For what it's worth, that lens sold new for $159 in 1957.
Amateur Anamorphotic Adapter Lenses
David W. Jones
www.joneshdfilms.com
Old September 13th, 2013, 11:22 AM   #3
You've answered a slightly different question than the one I asked.
I was asking whether the lens would actually provide enough of a projection for the 4K part of the 1DC's sensor - I'm thinking that it won't and trying to clarify that.
You totally avoided dealing with that issue and introduced three others - perhaps because you think they trump it.
They don't! Remember you're not aware of the effect I am trying to create or project I am working on.
I ask again: Am I right in thinking this lens could not be used with an adaptor to shoot with the 1DC in 4K mode because the glass only covers 16mm?
Old September 13th, 2013, 12:15 PM   #4
Well the lens was designed to cover a 1:33 regular 16mm Bolex size frame, and then 2x up to 2:66, removed from the Bolex, and then mounted to the projector to un-squeeze the film. There is no way by it self it would cover the 4K sensor in your camera. But hey, through some combo of this lens mounted to your taking lens you might be able to achieve what ever effect you are trying to get that I don't happen to be aware of.
All the best!
Dave
David W. Jones
Old September 14th, 2013, 01:35 AM   #5
Thanks Dave - that's what I needed to know!
Old September 14th, 2013, 05:54 PM   #6
Which is $1278 in today's currency.
-- peer
www.NoPEER.com
Old September 14th, 2013, 07:33 PM   #7
Seeing that you're interested in buying an anamorphic lens for your 1DC, I was thinking that perhaps you'd be interested in my Zeiss/ISCO-36 f/1.4 anamorphic lens which I'm not using. It's in very good shape.
Here's lowlight test footage with it mounted on my old 5D2:
And here's a silly clip showing the entire rig, including the lens:
If interested, give me an offer.
-- peer
www.NoPEER.com
Peer Landa is offline   Reply
