Proper setting on CS6 for the C100? at DVinfo.net
Old August 30th, 2013, 10:18 PM   #1
What are others setting on preferences for the C100? I'm shooting with the Ninja and every time I go to edit it asks me if I want to use the the setting on the computer or setting shot on the camera.
Bill
Bill Scherer is offline   Reply With Quote
Old September 5th, 2013, 02:56 PM   #2
Re: Proper setting on CS6 for the C100?
Setting you shot in the camera.
James Davis is offline   Reply With Quote
Old September 15th, 2013, 04:14 PM   #3
I now have time to clarify my question. If I'm using the Ninja 2 with the C100 and obviously shooting Prores,
what is the sequence Preset settings to be used in Premier Pro for loading and editing?
Bill
Old September 15th, 2013, 11:09 PM   #4
Suggestion: Accept whatever default sequence settings come up when you start the sequence. Import your files and drop a representative clip on the timeline. When the "mismatch" window opens, select "Change sequence settings" and Premier will set the sequence to whatever the clip is. This is not, iirc, available in earlier versions than CS6, however. This presumes you wish to edit in the clip's native format, which is a good idea. You can output your sequence to Media Encoder and make it whatever you wish, when the time comes to do so.
Old September 16th, 2013, 02:39 PM   #5
Thanks Battle I'll try that.
